Results 1 to 9 of 9
Thread: Buckeye small Vessel
    Palm Springs, Ca
    1,169
    I spent part of the day turning and playing around with a small piece of Buckeye I had (see picture below). Turned it much thinner then i was originally going to but it was cutting so nice and i could feel the cutter on the hollowing rig slicing easily. I adjusted the laser to cut thinner because the wood was cutting so good. When I was done and parted it off i was suprised to feel how light this wood is.....like feather light.......LOL
    Picture below shows it with 1 coat of DO on it.......I like how the buckeye has all those voids and colors scattered all over it....lots of character ya know..............more later when i put the finish coats on ....
    thanks Dan
    30,017
    Very cool piece. Do you oil the inside too, or just the outside?
    really nice!! but it not hold water!
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Palm Springs, Ca
    1,169
    yeah your right - I would not want to drink out of it............LOL
    I used linseed on the inside of it but the camera and lighting seem to show a white inside,when actually the inside is similar to the outside. I have some linseed in a bottle that i use to coat the inside of my vessel with after turning and then coat the outside with AO or DO. Then i just leave them sitting out on a wood shop table in the garage and let them air dry for a week or more before i start my finishing. I have been doing this for a bit now and no cracking or checking but then again the summer heat is not here yet so........we will see................always experimenting......LOL
    Just a note - regarding buckeye - this stuff can fly apart easy when turning due to voids, punky areas etc----if it looks like that is going to happen I use painters tape (blue or red stuff) and wrap it on the lathe. Do not use duct tape-----guess how i know that......LOL - the tape will hold everything well and when the hollowing is done and you remove it the inclusions will show nicely...........anyway thanks............Dan
    Vaughn - I did get some cutters from Enco with colbalt they were almost the same price and your right I don't notice a difference in cutting and im not sure if it holds a edge longer - it may..... The buckeye cut easy v. the mesquite i usually turn that is drier and harder to cut. Buckeye is truly green whereas the mesquite has been sealed and sitting for close to a yr now and I can tell its much drier. Actually, I don't bother with bagging/boxing etc with the mesquite now I just turn it and do the above and for this wood it works well - I will have to see if it hold true for the green buckeye (oiling and sitting that is)..........
    Jul 2007
    DSM, IA
    5,719
    Very nice Dan! Looks like it was easy to get the shavings out of the inside with all those voids.
    My Website
    Goodland, Kansas
    4,834
    Nice looking piece Dan.
    Bernie W.
    Jul 2007
    Des Moines, IA
    854
    Beautiful piece, Dan. Had to be a challange to turn, but worth it.
    Vernon, WI
    230
    Nice work Dan, sure looks cool. I like all the colors in that wood
    Palm Springs, Ca
    1,169
    Thanks to all..............Dan
  1. buckeye burl
    By John Daugherty in forum Classified Ads
    Last Post: 04-28-2013, 06:57 PM
  2. small hollow vessel in desert oak
    By neil mackay in forum General Woodturning Q&A
    Last Post: 01-05-2013, 11:36 PM
  3. Small Walnut vessel - Shellawax finish
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 06-29-2011, 09:43 PM
  4. Buckeye Vessel and Jaw Question ?
    Last Post: 10-25-2010, 01:20 AM
  5. Another Buckeye box
    Last Post: 12-11-2008, 03:24 PM
