Results 1 to 10 of 18
Thread: Vacuum Chuck
    Kaneohe HI.
    70
    Vacuum Chuck
    After months of planning and researching, finally got my vacuum chuck completed. With help from Richard Schlumpf and members the Honolulu Wood Turners it's done and works great. In fact it sucked the bottom out of a bowl I used to test the vacuum. Forgot to adjust the bleed valve. Got some pics.chucks
    Pic 1: Rotary adapter connected to hand wheel, 3",4"
    Pic 2: My home made rotary adapter, made of corian ,2, sealed bearings and O rings
    Pic 3: Yellow Jacket 6 CFM pump, pulls 29hg. respectively
    Information courtesy of Family Woodworking , Sawmill creek, AWW, Woodcentral, Woodturners Resource, Honolulu Wood Turners
    Attached Thumbnails Attached Thumbnails DSCN0317.JPG   DSCN0318.JPG   DSCN0319.JPG
    30,017
    Wow...29 inches. That'll indeed suck the bottom out of a bowl. You're gonna love having the vacuum rig.
    Looks great John
    +1 on the "You are going to love it" comment
    11,833
    Looks good. That is a serious vacuum pump ye got there.
    Tellico Plains, Tennessee
    4,353
    That's a really nice looking set up... need to put one together myself... might have prevented my black eye..
    Chuck
    Tellico Plains, TN
    Goodland, Kansas
    4,834
    Looks great John.
    Bernie W.
    5,172
    Nice rig, John. I have the same lathe and several pumps. Would you please share more specifics about the Corian rotary adapter? I have a double sealed bearing and much experience with vacuum clamping for flat work. I also already have some vacuum bells to hold the bowls. Just need to get an adapter made.
    Kaneohe HI.
    70
    Rotary adapter
    Carol, I used 5 pieces of Corian, 3" X 5". Used medium CA glue to bond them together. Next day I turned them to slightly larger than the hand piece of the lathe. Used 7/8" O.D.x3/8"i.d. sealed bearings(2) from Enco. Drilled a 7/8" hole 1/2" deep. The other end I turned it slightly smaller than the diameter of the hand wheel and drilled a 5/16" hole. I used 4 O-rings I think they were 11/32" and placed them along the tube. turned grooves to seat the rings. The last one is just used to seal between the hand wheel and the adapter. Corian is brittle so you have to turn it slowly. Hope this helps.
    Rhode Island
    800
    John,
    Did you use 2 sealed bearings back to back???
    Kaneohe HI.
    70
    Rotary adapter
    Chuck, I did use 2 sealed bearings. Just to be sure it doesn't leak. Also ,I reversed the brass fitting and attached the bearings to the barbed side, which could accept the 2 bearings. The threaded side would have been too short to mount both bearings. Filed them down and used epoxy to secure them.Works well with no leaks.
  1. Vacuum Chuck
    By Jim Krager in forum Neander Tool Questions and Show & Tell
    Last Post: 09-23-2011, 07:02 PM
  2. Vacuum chuck?
    By Leo Voisine in forum General Woodworking Q&A
    Last Post: 08-09-2009, 07:20 AM
  3. Vacuum chuck?
    By John Ryan in forum Turning Tool Questions and Show & Tell
    Last Post: 08-10-2008, 10:22 PM
  4. another vacuum chuck system
    By Clark O'Neill in forum General Woodturning Q&A
    Last Post: 04-03-2008, 12:41 PM
  5. Vacuum Chuck ?
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 11-02-2007, 01:14 PM
