Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Sewer smells
    The Heart of Dixie
    4,268
    Sewer smells
    Got a mystery on my hands and someone probably knows the answer. I started getting a sewer smell in my house the last few days. Being a Home Inspector I can find it, right? I understand the basics of plumbing and first suspected a P trap had lost it's water seal. So I went to the bathtubs and ran water since they are least used fixtures in the house. Assuming the water had evaporated in the P trap. This happened once before so I was sure that was it.
    Didn't fix it.
    So I ran water in all the fixtures just to make sure the P-traps had water in them. Still smell it.
    I have partial basement and 85% of the plumbing is in there. I smell it there and that may be where the smell starts and works into the house. No plumbing leaks and I use the fixtures down there regular too. But I ran water in all them to make sure they were sealed too.
    That didn't work so this morning I crawled under the house. I am thinking a line might have broke in the crawl space. Nope and no leaks or smell there either. Then I Climbed on the roof to check the vents and everything looks good.
    Now I am stumped! The only way I know for a smell from the septic tank to get into the house is though a drain line. Either a broken line or empty P trap and I can't find either. Anyone think of something I missing?
    Custom built boats and Kits
    vent might be plugged?
    The one drain that gets forgotten alot is the floor drain in the utility room in our basement. It has a p-trap too but it's below the concrete floor.
    Ken
    Constantine, MI
    7,891
    Any chance the tank is either over flowing or leaking and seeping into the ground near a foundation vent? How close is the tank to the house?
    www.wrworkshop.com
    The Heart of Dixie
    4,268
    Todd, I thought of that and that is why I went on the roof to look. If it was clogged I would expect the toilets to empty all the water out. So I am thinking that is not it.
    Ken, no floor drains but that would be a good one to miss and would make total sense.
    Rennie, to far from the house. Plus I would probably smell it outside.
    Smell is not really strong so that is what is making it so hard to tell where it is coming from. I been spraying poly the shop this morning so my fan is going sucking air out. That should pull the smell out and maybe if it comes back and I narrow down where it is starting.
    Sep 2007
    Central (upstate) NY
    1,457
    Any chance it could be a decaying, dead rodent or something? Or refuse from a live rodent?
    The Heart of Dixie
    4,268
    I don't think so. I should be able to locate that if it was. I went under the house in the crawl space thinking it might be something under there and not in the basement section or inside the house.
    I am really stumped.
    Just went to the shop and fan is going and I smell nothing but the faint smell of the waterproofing I am spraying. So maybe this will remove the smell and if it comes back I figure where it starts.
    new york city burbs
    10,188
    I dont know much, but Ill add my 2 cents.
    Whenever barametric pressure in the atmosphere change, like during a storm, or whatever, sewer gases, and Im not sure which is heavier, the sewer gases, the air....but if theres a chance of them leaking in a tiny crack of a sewer vent, they will be most prominent when the pressure changes.
    I dont think the venting outlet itself will have an odor, it may be somewhere along the line, in the walls, floor, attic?
    The Heart of Dixie
    4,268
    OK, I think I am onto something. Someone mentioned they had seen this happen in the spring when there were high winds. I had another house that every time we had heavy rain you would smell the same thing and sometimes when it was very windy. I had forgotten about that too. That house was built on a slab so I assumed there was a problem with the plumbing since I couldn't see it.
    Now I still don't know why high wind would cause this but it did start the day we had some really strong winds. And since my other house did this I think this is related to the wind. But why it would cause this I still don't understand. But it sort of lines up with what you were saying Allen.
    do not intend to hi-jack this thread but what is the purpose of the vent pipe /
    I've heard different versions for the vent pipe
  1. My Yard Smells Like a Taco
    Last Post: 06-28-2010, 05:49 AM
  2. Favorite smells?
    By Westley Rosenbaum in forum Off Topic Discussion
    Last Post: 04-14-2009, 03:32 AM
