Results 1 to 10 of 11
Thread: my new dovetail jig
    Sep 2007
    Central (upstate) NY
    1,457
    my new dovetail jig
    Bellingham
    2,449
    When do we get to see it action?
    Sep 2007
    1,457
    I had to do work before play tonight and use a slightly different saw to cut the muffler off our parts car. Will go butcher some wood after eating.
    May 2008
    Bellevue, WA
    38
    Gee, that is the same one I got just a week back. I've only done a little with it, but it is much better than the Japanese Dove Tail jig I had been using. I've found it cuts to a line more accurately and easier than the pull saw I had been using.
    Dick
    17,470
    how is it to start the cut mark? and after you get a batch made you need to show us your pics..
    Sep 2007
    1,457
    No pics yet, but I have learned some things already.
    1. Don't chop when you can saw.
    2. Don't chop off the tails.
    3. When drawing the tail lines, it is rather helpful to put the narrow ends of the tail receivers to the edge of the board.
    4. I either need to sharpen my chisel better (probably), get a better quality chisel (instead of the Farm Hand brand from TSC) or maybe even get a coping saw that accepts scroll saw blades to cut waste. Regardless if I chop or cope, I also want to get a really nice paring chisel.
    5. When sawing at an angle, match the blade close to the angle until almost to the line, then slowly bring the blade around to cut through to the straight.
    Also, I suspect my tail / receiver alignment relative to the board edges is backward, but this is a design thing and irrelevant to my dovetail cutting ability. Also, this first one I cut the receivers before ripping tongues and grooves off of the free pine I'm practicing with - so might look aesthetically bad in addition to poor craftsmanship.
    I find myself needing to do about three back cuts to establish the kerf before the cutting is smooth. Larry, I hope this answers your question, but keep in mind this is my first precision hand sawing.
    Ok, back to the vise.
    Sep 2007
    1,457
    Here is my very first handsawn through dovetail!
    I ended up starting over after realizing my first attempt wouldn't work due to too small pins on the outside.
    It is still a bit tight, but I am done working with tools for the night.
    One other thing I learned is that if you have two pins, remove the waste between the pins before sawing off the waste outside the pin.
    30,008
    Nice-looking jig, but I'm not sure how it works. Does the router attach onto that metal part or something?
    Congrats, Mark. Although I wouldn't know how to use it right, I've admired that new line of Lee Valley saws since they came out.
    Sep 2007
    1,457
    Vaughn, I held the saw at the recent show in Saratoga, NY and it just fit my hand. Kinda like the way my 1911 fits. That rosewood sure is easy on the eye too!
    Central NY State
    3,374
    Off to a fine start there Mark!
  1. Dovetail saw kit
    By Toni Ciuraneta in forum Handtool Project Showcase
    Last Post: 12-03-2010, 07:10 AM
  2. new use for dovetail jig...
    Last Post: 09-17-2009, 04:42 PM
  3. Dovetail jig
    By Al killian in forum New Tools
    Last Post: 12-27-2008, 04:38 PM
  4. Dovetail jig
    By Ned Bulken in forum New Tools
    Last Post: 10-11-2008, 10:57 PM
  5. How about a dovetail box
    By Bob Noles in forum Flatwork Project Showcase
    Last Post: 08-15-2007, 06:39 PM
