Results 1 to 7 of 7
Thread: Old Bandsaw Blade Tool
    S E Nebraska
    35
    I saw one of these in Lee Valleys email flyer and it prompted me to show this one I made 30 some years or so ago. They call theirs a Drawing Bow and I call mine a Radius or Arch Marker.
    That old worn out or broken wide band saw blade, you will probably throw away will make a nice tool. Cut off a nice length or several different lengths and grind the teeth down or just leave them and cut a single shallow notch in one end in the middle and another in the other end with an extra one between the tooth edge and the center. Get rid of all the Burrs so the notches are smooth .
    You can use string or masons string line a little longer than the piece of bandsaw blade and tie a knot close to both ends.
    Reverse the natural bow of the old Band Saw Blade and and slip one end in the single notch, Bow the blade to whatever Radius you want and slip the string in the middle notch of the other end and wrap it several times in the two notches to secure it. Lay it down on your work. Lay a scantling across it so you can hold it down with one hand and them mark around it for your Radius.
    You can even make small radius tools from narrow bandsaw blades.
    Drawknife, Spokeshave, Plane, Rasp; Decisions, decisions.
    Old tools are all very MODERN, they are all CORDLESS.
    By Hammer and Hand All Arts Do Stand.
    Wake Forest, NC
    292
    That is a good idea! I will definitely be using it.
    Thanks
    Houston, Texas
    2,323
    Hi Jr,
    That is a good one. I bet the curve is perfect, thanks for a great tip
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Steve Clardy Guest
    Great tip
    688
    Great tip. I've ground down pieces of old blades to make beading tools, too.
    Nova Scotia's beautiful south shore
    443
    Hey, Jr - you trying to put Lee Valley out of business ??
    I guess they'll survive. Great tip. I think I know where I can get some decent sized used blades then I'll give it a whirl.
    Thanks
    Ian G
    Zushi, Japan
    739
    That's a good one. I just happen to break a blade and whenever I need an arch I am always searching for a good piece of clean straight grained wood.
  1. Bandsaw Blade ?
    Last Post: 03-28-2015, 08:41 PM
  2. Jumping bandsaw blade
    Last Post: 01-09-2010, 01:07 PM
  3. Bandsaw Blade
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 01-09-2010, 01:26 AM
  4. Bandsaw Blade Sharpening?
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 01-12-2007, 05:38 PM
  5. What bandsaw blade?
    By George Conklin in forum General Woodturning Q&A
    Last Post: 11-26-2006, 01:07 AM
