Results 1 to 5 of 5
Thread: Sharpenig a bedan
    Kaneohe HI.
    70
    Sharpenig a bedan
    How would you sharpen a Bedan tool on a grinder? The bevel only and the two sides, or just the bevel.
    You only sharpen the bevel side, so the bevel goes against the grinder. It is not the easiest tool to sharpen, but, thankfully, you don't have to sharpen it often, as once it is off the grinder, you use a hone, I like the #600 diamond hone I have for doing this. Then all that is needed is honing from time to time and unless you drop it or something it does not need to see the grinder again for a LONG time.
    Apr 2009
    Outside the beltway
    5,254
    If you have the money for a TorMac they have a jig and a honning wheel. It is nice.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Goodland, Kansas
    4,834
    Stu hit the nail on the head. It doesn't have to be sharpened often and just the bevel side. I also use a 600 grit diamond hone in between.
    Bernie W.
    Hardinsburg, KY
    277
    Is the 600 grit diamond hone what most places call "coarse"?
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
  1. The Bedan
    Last Post: 06-03-2008, 07:00 AM
  2. Home made Bedan
    By Terry Quiram in forum Turning Tool Questions and Show & Tell
    Last Post: 03-12-2008, 01:37 PM
  3. Sharpening a Bedan
    By Alex Reid in forum Turning Tool Questions and Show & Tell
    Last Post: 01-12-2007, 08:26 AM
