Results 1 to 5 of 5
Thread: What is that thing ?
    Smile What is that thing ?
    My Neighbor has cancer and his sister and brother in-law are visiting. The brother in law is a contractor in Hawaii and wanted to build a ramp so it would be easier to get the wheelchair in and out of the house. He came over and asked if he could use my table saw to cut some angles for the ramp so I gladly helped out. Said he's got a delta table saw he uses in his shop. I had the cross cut sled on the saw so I took it off and hung it up and spun the saw around to the rip position then I stood buy in case he needed any help. He asked me for a push stick which I gladly supplied him with, he had his own safety glasses. I turned on the dustcollector and played helper to him, he looked like he knew his way around the saw, I let him use my block plane and some chisels and he had no problem using them, even asked for my mallet instead of a hammer for the chisel. All in all he did a fine job. Later on I went over to see if he needed any help which he didn't then he asked me, "Say what was that thing you took off the saw and whats it used for". I guess contractors don't do a lot of crosscutting..
    3,132
    My Neighbor has cancer and his sister and brother in-law are visiting. The brother in law is a contractor in Hawaii and wanted to build a ramp so it would be easier to get the wheelchair in and out of the house. He came over and asked if he could use my table saw to cut some angles for the ramp so I gladly helped out. Said he's got a delta table saw he uses in his shop. I had the cross cut sled on the saw so I took it off and hung it up and spun the saw around to the rip position then I stood buy in case he needed any help. He asked me for a push stick which I gladly supplied him with, he had his own safety gslaases. I turned on the dustcollector and played helper to him, he looked like he knew his way around the saw, I let him use my block plane and some chisels and he had no problem using them, even asked for my mallety instead of a hammer for the chisel. All in all he did a fine job. Later on I went over to see if he needed any help which he didn't then he asked me, "Say what was that thing you took off the saw and whats it used for". I guess contractors don't do a lot of crosscutting..
    Don most of the crosscutting we do in the field is done with a circular(skil) saw.
    Steve
    Apr 2009
    Outside the beltway
    5,250
    Don I see you have not done much construction work outside the shop
    It can get dangerous out there , stay inside bud. I am
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    13,353
    I thought this was the preferred method of crosscutting for contractors..
    http://www.youtube.com/watch?v=IHGIwCHfESg
    11,825
    Left over April 1st farce.
  1. Some thing different
    By Chuck Thoits in forum Lathe Project Showcase
    Last Post: 03-18-2010, 07:39 PM
  2. just did the right thing
    By Mark Kosmowski in forum Off Topic Discussion
    Last Post: 03-28-2009, 01:57 PM
  3. Another DNA thing
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 01-19-2009, 04:04 PM
  4. The whole DNA thing?
    By Paul Downes in forum General Woodturning Q&A
    Last Post: 03-14-2008, 05:05 PM
  5. If it's not one thing, it's another! It's always something!
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 03-02-2008, 10:01 PM
