Results 1 to 10 of 13
Thread: fret saw or coping saw
    Sep 2007
    Central (upstate) NY
    1,457
    Why would you want one of these over the other?
    Central NY State
    3,374
    Mark, a good fret saw can accommodate a wide variety of very fine blades, it works much better than a coping saw for removing the waste from dovetails. I use mine all the time for that purpose. A coping saw can get you through thicker wood and heavier duty jobs. They aren't for the same task. For doing trim carpentry, a coping saw is more suitable. For cleaning up dovetails, the fret saw is preferred. It isn't an either or, it's both, but then again, as you know, I am a tool pig.
    Sep 2007
    1,457
    Thanks! I'll budget a little extra for the next LV order then and get one of each and a variety of blades.
    Central NY State
    3,374
    Mark, out in my shop I have the size fret saw blades recommended by Rob Cosman for cleaning out DTs, I can't remember what they are, but I can send you the info.
    Sep 2007
    1,457
    That will be great!
    Austin, Texas
    1,448
    Doesn't a Fret Saw take your scroll saw blades?
    Charlie Plesums, Austin Texas
    13,360
    Oddly enough, This is what came into my mind when you said fret saw.
    A saw that's used for sawing fret slots. I guess I don't really see much difference between a "Fret Saw" and "Coping Saw" as you guys are discussing?
    I've also got 'Jewelers' saw, for cutting mother of pearl inlays, which is also similar to a fret saw or coping saw, but is adjustable in blade length and uses some very fine blades..
    I've got this setup for sawing fret slots...
    http://www.stewmac.com/shop/Tools/Sp...xst=3&xsr=1366
    Bellingham
    2,449
    I use a coping saw that works great. It is the Olsen Deluxe Coping with a 18 TPI skip tooth from Tools for Working Wood. It easily fits into the cut left by my dovetail saw and can turn a tight radius. Check it out.
    5,321
    Quote Originally Posted by Bill Satko View Post
    I've got one of these, and I really like it!
    13,360
    Now that looks like a nice little jewelers saw!
  1. Fret Slot Jig
    By Ted Calver in forum All Things Musical
    Last Post: 09-12-2015, 03:56 AM
  2. New Fret Saw
    By Jay Caughron in forum Old Iron
    Last Post: 06-20-2015, 02:19 PM
  3. Shop made fret wire bender :D
    By Jason Beam in forum Jigs and Fixtures
    Last Post: 09-18-2013, 03:58 AM
  4. What happened to 6" fret saw blades?
    By GARY FOSTER in forum Neander Woodworking Q&A
    Last Post: 04-29-2010, 01:26 AM
  5. Coping Saw
    By Ed Nelson in forum Neander Tool Questions and Show & Tell
    Last Post: 04-08-2007, 10:38 PM
