R
ray hampton
Guest
well, call me confuse but are this collet the one that hold the bit in the router
Jim I plan on getting a new collet and bit tomarrow but I was wondering since I am doing 1/2" dove tails then I should be able to cut the dove tails without a collet, it will change the profiles a bit but that should be OK..
OK Chuck you convinced me..If ya don't use the collet the bit will fall out.
As for the dove tail guide I know my dove tail jig would not like a spinning bit rubbing on it.
Heck as much as I bee messen with this jig and the router bits, I would have been better off going back and cutting them by hand..
What jig I don't see no jig.
Does any one else see a jig?
I guess you memory is short I posted a picture Here.
Yes the router is brand new, that why the confusion in the first place, Although I got it in august the only time I used it was to test out the jig. The bit was also bought at the same time but I used the bit in my router table quite a bit with another router that is not nearly as new.Hey look theirs a jig and a nice shinny new router. Is taht router as new as it looks?
If so one would not think the collet would be worn out all ready.
Have you look online to see if any one else is having this problem with this brand router?
I gots me two of those routers and neither have given me any fits like this. It's quite strange what yer seein'.
My only guess is a bad bit? I dunno ... i don't think collet size is a factor here. It's possible the 1/4" collet was a dud, but every one of my milwaukee tools (at least 4 that i can think of off hand) are of the utmost quality - though mistakes do get through even with the best of 'em.
I don't disagree with the friction physics, but I'm not sure that's the only thing at play. The force applied to the mating surfaces will have an impact on how well it'll stick. If a 1/4" bit comes loose in a collet designed for it, something's wrong with that bit or that collet. Like I said, I've spun 1/4" bits much bigger'n 1/2 dovetail bits in the milwaukee routers I have with no problem what so ever.
I suspect the bit, just because I have no reason to doubt the quality of the collet - besides fluke friday-manufacturing
