Results 1 to 10 of 11
Thread: Stanley Compressor (dead)
    Oct 2008
    Mobile, AL
    46
    Not sure where to post this. I have a 6 gallon Stanley compressor and I think the pressure switch went out. It'll pressurize the tank to about 20psi and no more. Continues to run and when I shut it off it rolls to a stop instead of stopping instantly. Does that sound like a bad pressure switch? Or could it be something else.
    Thanks, Bill
    Nov 2009
    Windsor,Ontario
    20
    Check for air leaks. I have a compressor that was doing something very similar and I discovered it leaking air at the head gasket. Mine would only build to about 30psi and just continue to run.
    I don't think it's the pressure switch as you stated the compressor continues to run, but won't build pressure up.
    Brian
    5,319
    It's not the pressure switch.
    More likely, it's a leaking or broken reed valve in the compressor head. Dirt can get under the intake reed and hold it open, which will cause the problem you describe.
    There's also usually an air tube from the compressor to the pressure switch. If it's loose and leaking, then that could cause the problem, but you'd usually see and/or hear the leakage in that case.
    My bet would be the reed valve.
    Oct 2008
    Mobile, AL
    46
    Okay, this is where I need more help. I looked at the parts diagram for my compressor and I couldn't find the reed valve. I do remember that when I disconnected the tube from head to the tank and placed my thumb over the fitting on the head, I could hold it there with very little effort. Here's the link to the parts diagram for the compressor. http://www.bostitch.com/default.asp?...-OF&serialNum=
    Look at 06 an 77 on the diagram.
    Last summer we found a crack in the line running from the compressor to the holding tank. couldn't make pressure but continued to run, and run, and run...
    Oct 2008
    Mobile, AL
    46
    Thanks Don, I already priced those parts. I should probably replace the head/plate gaskets too right?
    Quote Originally Posted by Bill Graupmann View Post
    I would..
    Oct 2008
    Mobile, AL
    46
    So I took the head apart this afternoon and guess what. I think I found the leak. The reed valve on the piston looks fine, but this one is toast.
    Thanks for the help Don.
    Oct 2008
    Mobile, AL
    46
    That's what it was Jim, thanks!
  1. Firefox id DEAD
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 06-01-2016, 02:39 AM
  2. The Walking Dead
    Last Post: 02-11-2013, 05:23 AM
  3. dead duck
    By ken werner in forum Off Topic Discussion
    Last Post: 03-10-2010, 01:07 PM
  4. Another Dead Computer.....
    Last Post: 12-17-2008, 01:58 PM
  5. ROS dead or alive??
    Last Post: 03-11-2008, 10:38 PM
