Results 1 to 7 of 7
Thread: Injected Epoxy?
    Dec 2009
    Madison, WI
    206
    Injected Epoxy?
    A friend of mine has a studio monitor which, during a party, fell off of its' stand and developed a major crack. The enclosure has twisted along the crack, and while I can clamp it back into shape easily enough, I need an appropriate glue that I can inject into the extremely narrow fissure that will hold the plastic and MDF together. Can anyone recommend a low-viscosity glue that can bond these materials, perhaps one that I can inject into the crack with a syringe? I was considering some sort of low-viscosity cyanoacrylate.
    Dec 2009
    Kemah, Tx. - Houston Suburb
    95
    You will have to find a small area of the plastic to make a 'test' gluing. CA Glue and epoxies wont stick to certain types of plastics. Since CA glue is more likely to stick to the plastic, I would experiment with it first. Find a backside or place that would not normally be seen. Spread a small amount of CA glue on it. When it is dry, see if it will scrape off easy or not. If it comes off easy, try same experiment with epoxy. If neither work, go to a hobby shop and see what glues they have for plastic.
    No need to experiment on the MDF because we know both will stick to it.
    11,832
    Look for #100 CA.
    Dec 2009
    Madison, WI
    206
    Look for #100 CA.
    You mean like 100% methyl cyanoacrylate?
    11,832
    Quote Originally Posted by Joseph Shaul View Post
    No. Viscosity of CA is designated in hundreds. #100 is as 'thick' as water and it goes up from there, #200, #300, etc. I have some #200 and can't tell it is any thicker than water. But for injection, #100 would probably be safest choice. I have a friend who sells CA, if you can't find what you need, contact me and I'll put you in touch with him.
    Apr 2009
    Outside the beltway
    5,255
    Look up Triple 7 They make one of the best epoxy's. I've used it for years and once a repair is made with it , the 24 hour stuff it will not break again in that spot.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    The Heart of Dixie
    4,268
    If it cracked all the way through, you can pull the glue through the joint with a shop vac. Just put the hose against the crack and the glue on the other side. WaaLaa!
    Custom built boats and Kits
  1. Epoxy question
    By Charlie Plesums in forum General Woodworking Q&A
    Last Post: 03-11-2015, 04:34 PM
  2. Black Epoxy
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 12-13-2014, 03:24 PM
  3. Need some epoxy recommendations
    By Tom Baugues in forum Off Topic Discussion
    Last Post: 10-09-2014, 02:23 AM
  4. What did the Epoxy say to his friends?
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 03-11-2012, 04:12 AM
  5. what epoxy?
    Last Post: 06-02-2010, 05:21 PM
