Results 1 to 4 of 4
Thread: Kind of a strange hardware question....
    Rochester Hills, MI
    940
    Hi folks,
    I'm trying to find some hardware for a project I'm working on for a customer. It will involve using some probably 1/8" steel cable. (wire rope) I need to put some stops at particular points along the cable. I could use a sleeve and just crimp them on but then they'll be permanent. I'd like to make them adjustable if possible. What I thought they would be called is a "collet". Basically a short metal sleeve that would slide over the cable. But I was hoping to find one with a set screw in it. Then I could place the stop where it needs to be and just tighten the set screw. But any search I do for "collet" brings up something completely different. A collet is basically used in routers and machine tools. It is what the bit slides into and then a nut gets tightened down to hold the tood in place.
    I hope I'm describing this sufficiently for you to understand what I'm looking for. Does anyone here have a better idea of what to call that or where to get something like that?
    Any help would be GREATLY appreciated!
    Take care
    John
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Rochester Hills, MI
    940
    Nevermind!
    A couple minutes after making this post, I realized that I'm looking for a "shaft collar". Not a collet.
    Carry on with your daily business.
    John
    17,475
    was gonna suggest drilling and tapping one but you got your source already hows the world in detroit john? we are now in sunny california
    Rochester Hills, MI
    940
    Actually the weather is BEAUTIFUL at this point! I love Spring. Hope things are well with you and the gang out there on the coast.
    John
  1. Jig Hardware Question
    By Cynthia White in forum Jigs and Fixtures
    Last Post: 11-22-2011, 02:31 PM
  2. Strange question re: stabilizing tobacco
    By Doug Miller in forum General Woodturning Q&A
    Last Post: 08-03-2009, 02:12 PM
  3. bed hardware question
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 11-16-2008, 07:31 PM
  4. Cabinet hardware question...
    By John Pollman in forum General Woodworking Q&A
    Last Post: 09-18-2007, 09:22 PM
  5. Sliding Door Hardware Question
    By Wes Bischel in forum General Woodworking Q&A
    Last Post: 01-30-2007, 11:37 PM
