Results 1 to 3 of 3
Thread: Save your fine wood dust
    Apr 2009
    Outside the beltway
    5,253
    Something I was thinking of this morning while gluing up a few cherry chairs. I have sandwich bags of fine wood dust hung on the wall to pull down to mix with a glue or epoxy to get the color of the joint correct, you know that ding or maybe little exposed gap you need to fill with hot wax. This will help elevate that problem.
    Another good use for the dust is filler. Use a drop of lacquer sealer in a small pile of the dust you need mix it well and use a razor blade to apply the mixture. Great way to avoid those unsightly crack or ding repairs.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    10,604
    Great idea. I'll start using that tip today
    30,014
    I also have a variety of Ziplock bags with fine sanding dust of different colors. Don't need to use the dust often, but when I do, it sure is handy having a selection of colors to choose from.
  1. I was able to save it
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 04-22-2016, 01:02 PM
  2. New app that may just help save lives
    Last Post: 10-13-2011, 11:23 PM
  3. Save Phonehenge!
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 06-09-2011, 11:15 PM
  4. I Save My Wood Shavings ...............
    Last Post: 06-24-2010, 03:39 PM
  5. hope i can save it
    Last Post: 03-17-2009, 10:06 AM
