Results 1 to 10 of 11
Thread: glueing melamine
    Sep 2007
    Central (upstate) NY
    1,457
    glueing melamine
    If I wanted to glue two pieces of melamine at a right angle for a jig, would it be wise to rout a rabbet in the one piece to remove the melamine?
    If so, will any router bit do the job or is there a special bit that should be used?
    Quote Originally Posted by Mark Kosmowski View Post
    let me first say that I don't work with melmine or any of those type of products. But I'd, definily do a rabbit and just use what ever bit I got that would do the job. Perhaps some of the guys who do production work will pipe in and tell you otherwise.
    4,553
    Don's right Mark you will have to rout a rabbet to remove the melamine. Regular glue will not stick to melamine it takes a special glue for that. Any router bit will work but make sure you have a dust mask and face shield on as it is a very dusty job to do.
    Jay
    A Turn N Time
    Frog Pond Guitars
    9,077
    I also don't use melamine generally but have heard folks speak of Roo-Glue for this.
    4,553
    Thats the one and as far as I know its the only one.
    Jay
    A Turn N Time
    Frog Pond Guitars
    roo-glue works.
    Sep 2007
    1,457
    This is the roo-glue you're all talking about, right? Thanks!
    4,553
    That's it Mark but you really only need it if you are gluing melamine face to face. If you are going to make a rabbet or dado you can use regular glue and be OK.
    Jay
    A Turn N Time
    Frog Pond Guitars
    Sep 2007
    1,457
    And a dado will help me align two slots to be parallel if I reference the same edge to the router table fence. If I ultimately want one of the dadoes to be a rabbet, I can start with a dado for parallel alignment, then trim down to a rabbet with a bottom bearing bit, right?
    4,553
    That should work Mark but what I do is cut panel to length and then just use a rabbeting bit to make the rabbet ( one with a guide bearing) in a hand held router.
    Jay
    A Turn N Time
    Frog Pond Guitars
  1. Melamine cutting
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 10-24-2009, 12:03 AM
  2. glueing up red oak, strength concerns
    Last Post: 08-07-2008, 02:44 AM
  3. 3/4" and 1-1/4" Melamine near Columbus, OH
    By Wes Billups in forum Old Ads
    Last Post: 06-16-2008, 08:00 PM
  4. FS: Freud LU97R010 - Dbl Sided Laminate/Melamine Blade
    By Keith Starosta in forum Old Ads
    Last Post: 06-06-2008, 01:39 PM
