Results 1 to 10 of 12
Thread: Anyone have a Wallstreet II "click" pen kit?
    May 2009
    Lafayette, Indiana
    2,380
    Does anyone here have a Wall street II click pen kit? I need to know what the tube length is. I have two click kits here but they have two different length tubes in them. I'm thinking that the twist version might use the shorter tube and the click version the longer??? I have a 2 1/4 and 2 7/16 tube. I'm not sure which is right. I cant seem to find the tube size online yet.
    Tom
    NH
    4,006
    I'm holding 2 Wall street II twists that are 2 3/16"
    The instructions say to cut the blank 2 3/8" long. So I would say the tube is the 2 1/4" one that you have.
    http://www2.woodcraft.com/PDF/77C52.pdf
    Stupid hurts.
    May 2009
    Lafayette, Indiana
    2,380
    Ok I found my answer. Chuck thanks for looking but I have the "Click" style Wallstreet II and I found out that it does take a longer tube than the twist pen.
    Tom
    NH
    4,006
    Every click I have found says 2 3/8" blank. Woodcraft Product #148461, 148462, 149178, 149243, 150307, 150309,
    150546
    The letter opener is the only thing so far I have seen with a 2 7/16" blank.
    Woodcraft Product #150549, 150550
    Stupid hurts.
    Rhode Island
    800
    Yeah, it does. Don't do what I did & assemble the wrong kit to the finished tube.
    May 2009
    Lafayette, Indiana
    2,380
    Chuck, my kit is #148462. The actual tube length is suppose to be 2.42.
    Tom
    NH
    4,006
    Quote Originally Posted by Tom Baugues View Post
    Tom
    Where did ya get that Tom?
    Some one should tell Woodcraft the instructions for this kit are wrong.
    copied right from the instructions for a 148462 1. Cutting Blanks
    Cut one blank 3/4" x 3/4" x 23/8" long
    As we all know 2 3/8" is quite a bit shorter than 2.42"
    I know I would say bad words when I couldn't get the pen together or to work because the instructions have you cut it short.
    Stupid hurts.
    Hardinsburg, KY
    277
    I might be nuts, but I never measure the blank by the instructions. Instead I measure by the tube that came in the kit. I normally give it 1/16 or so just to give me some room to square it with the tube. Seems to work though.
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    NH
    4,006
    Quote Originally Posted by Doug Miller View Post
    Your not nuts more than one set of instructions tell you to cut the blank X longer than the tube. Some tell you to cut the blank X shorter than the tube. But I have found that it's good to know how long the tube is supposed to be before you go cutting the blank wrong.
    It really shows up if you do pens from a lot of different companies. If one does pens from only Woodcraft and gets in the habit of how Woodcraft does things. You can end up needing parts if you don't read the instructions for that PSI or Rockler pen.
    Stupid hurts.
    May 2009
    Lafayette, Indiana
    2,380
    Chuck you are absolutely correct about the instructions being wrong. I have always just cut my blanks according to the tube size but if someone wanted to just cut up a bunch of blanks for this pen kit and only used the instructions to go by then all of those blanks would be too short. The instructions are correct for the twist version but not the click version.
    Tom
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. I just love "From Me" -- "To Me" Christmas presents!
    By Mack Cameron in forum Turning Tool Questions and Show & Tell
    Last Post: 01-29-2010, 12:06 AM
  5. Triangle - "Copy" and "Paste"
    Last Post: 01-12-2008, 09:37 PM
