Results 1 to 9 of 9
Thread: Natural Edge bowl warp
    Hi, a few months ago I rough turned my first two natural edge bowls from a chunk of maple. I did what I normally do and left the walls about 1" thick while it dried over a couple months.
    When I went to get the bowls to finish them, I noticed they had warped an extreme amount along the "length" ... so they are now oval shaped. I put one on the lathe and it had warped so much that I couldn't even get it back to round without completely chewing away the two "long sides". They were down to about 1/4" and I still had barely hit the other two sides.
    Is this normal for natural edge bowls? Should I be roughing and finishing them all in one session? Even with the extreme warp, there are no cracks at all. I really don't want to do any more until I find out the strategy I should be using as it appears to be different the other standard bowls I've done in the past.
    Dawson,
    NEs are the one bowl that I turn to finished size in one session. Then if it warps....it adds to the mystique and beauty IMHO.
    Ken
    Hardinsburg, KY
    277
    Agreed. NE bowls with a bit of warp just cause folks to be more apt to ask, "How did you do that?"
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Palm Springs, Ca
    1,169
    Agree - I also turn all my NE bowls to finish - let dry or oil soak etc and build the finish............
    Most of the NE bowls I've turned were done wet, and re-turned after drying. So far I've been lucky and none of my big ones have warped so bad I couldn't re-turn them round. I have had a couple smaller ones that warped quite a bit though, and by the time I got them round again, the wall thickness was down to about 1/16" or so at the rim.
    Tellico Plains, Tennessee
    4,353
    I can't attest to the truth, but I've heard that if you turn bowls from limb vs trunk wood you can get more extreme warping... seems the story goes that limbs have a different stress in the woods from the way they grew than do trunks... I have very poor luck doing NE bowls, so have done only a very few.
    Chuck
    Tellico Plains, TN
    Buse Township MN
    565
    It depends on how wet the wood is. I copy Vaughn if the wood is sopping wet...rough turn, let dry, finish turn. If the chunk has been sitting a year or more, I'll usually finish turn in one session...unless it is still sopping wet inside.
    Quote Originally Posted by Ken Fitzgerald View Post
    Dawson,
    I can't remember seeing any of your NE bowls Ken...got a link to some pics??
    Every child deserves a family. Adopt. Foster. Get involved.
    Manistique, Michigan
    297
    Has anyone soaked an natural edge bowl in DNA? I have only rough turned 3 bowls and have soaked all three in DNA. I havent worked up to a NE yet.
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    Goodland, Kansas
    4,834
    I used to do that Rich but now I turn them to finish generally 1/4" or less in wall thickness. As soon as I get the bottom finished I soak it immediately with Antique Oil. It has done wonders in controlling the cracking and warping.
    Bernie W.
  1. Mesquite natural edge bowl
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 03-06-2010, 02:16 AM
  2. in progress natural edge bowl
    Last Post: 03-05-2010, 12:12 AM
  3. Natural edge elm bowl
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 06-27-2009, 11:29 PM
  4. First Natural Edge Bowl
    Last Post: 02-12-2008, 09:17 AM
  5. Natural Edge Winged Bowl
    By Jim Ketron in forum Lathe Project Showcase
    Last Post: 01-29-2008, 06:03 PM
