Results 1 to 10 of 26
Thread: Chain Saw Grinder Question ?
    Palm Springs, Ca
    1,169
    I have been thinking of getting a chain saw bench grinder for my chain saw's. I know there are hand files etc -----. I really like the speed and simplicity of the bench grinder and I do not want to fool around with the hand files and jigs.
    When I take mine in to have them sharpened I see the guy behind the counter using a bench mounted grinder and he sets it quickly and zips along with this thing and within a couple mins the chain is sharpened. They also now have increased their price from $7.00 to $9.00 per chain. The other places nearby are charging as much or $10.00.
    So, I figure its time I find my own way to resharpen. I found this link but I thought i would see what other turners are using in the way of bench grinders.........better deals out there maybe???
    Oregon Bench Mounted Mini Grinder (115 Volt) at Bailysonline.com and it sells for $189.00
    Click here: Bailey's - Oregon Bench Mounted Mini Grinder
    Thoughts ???
    Thanks Dan
    3,134
    Chainsaw bench grinders are not all that great they shorten the life of your chain that's why loggers usually do it by hand, I use one that has a guide that clamps to the bar. Also the grinder sharpens to a vertical straight edge where as the file gives you a curved edge which stays sharp longer & cuts quicker. Lets face it 2-3 swipes with a file doesn't take that long to gain all of the above.
    http://www.tiltonequipment.com/html/...ngtools_92.htm
    This is the kind of tool to use skip the grinder that is unless you like a chain that get dull faster & buying replacement chains because of getting ground away wasting your chain also having to sharpen it more often thus wasting your chain.
    5,321
    This is the one I use. It takes maybe ten minutes to do a chain on a 16" bar.
    Nov 2008
    Tampa & NC
    432
    Chainsaw grinder question
    Sorry folks,but I have to disagree on part of this.I'v been sharpening chains for well over 40+ yrs and when used properly grinders won't shortin the life of the chain any quicker than a file.I am not taking anything away from using a file.When I am (also loggers) in the field,then I use a file sometimes,but usualy I will take a few extra chains with me,then when I get several chains dull,I will set up the grinder and sharpen them all at one time.Also with a properly setup grinder you will get a more precise sharpening,whereas unless you have a bit of experiance, after a few sharpenings with a file the teeth will not be uniform,causing the saw to work harder and not cut as well.When working for a living we had a profesional grinder,but I got one from Harbor freight that was on sale for half price 39.00 about 5 yrs ago and it works just fine.
    13,361
    Here's a link to the HF version.
    http://www.harborfreight.com/electri...ner-93213.html
    (Wow! Harbor freight redesigned their website and it's a huge improvement.)
    North West Indiana
    6,099
    I have a HF chain grinder, it worked wonderful until I wore out the plastic parts. It did a great job for the money. Heck after five chains it was paid for, think I got three years out of it. I still jury rig it but have been looking at Northern Tools catalog as they have three or four different ones and they look to be less plastic.
    Jon
    Tellico Plains, Tennessee
    4,352
    Jim that looks pretty slick... does it work really well? I have a hard time getting my chains sharp... it's just not a talent I've ever been able to develop... would save me lots of frustration...
    Chuck
    Tellico Plains, TN
    11,833
    Came back late. The HF model, also sold by others ($25 to $40 same rig) is just fine. As said, saves you money after just a few chains, when worn out, throw away and buy another.
    Some swear by hand filing. I swear at it. Even using guides, free hand, special cuss words, can never get satisfactory results.
    2,784
    I bought the little Dremel attachment a few years ago. Don't use a chainsaw often, so I've only used the thing one time. Worked great! Has 3 different grinding stones for different angle cuts depending on the chain. Was cheap enough too. About 15.00 IIRC. And I used a cordless Dremel to do it. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    5,321
    It works quite well. You just have to count your strokes, making sure to take the same number on each tooth, to keep the teeth even.
  1. Chain saw sharpening question
    Last Post: 11-14-2011, 03:05 PM
  2. Chain Saw Blade Cutting Question
    Last Post: 02-19-2011, 02:30 AM
  3. Chain Saw Question again
    Last Post: 09-04-2009, 12:50 AM
  4. Gas Chain Saw Question
    Last Post: 09-02-2009, 01:15 AM
  5. Grinder question
    Last Post: 06-18-2007, 03:08 AM
