Page 2 of 54 FirstFirst 1234561252 ... LastLast
Results 11 to 20 of 536
Thread: New Organ Build Topsy 3
  1. #11
    Mar 2010
    Maplewood, NJ
    78
    Jay,
    Got a question about Bellows Board B. It's impossible to tell from the drawing if there are three short "stiffeners" at each end, or two separated by a space. Your photos are a great help, but unfortunately, that part is already assembled, so I can't see the inside.
    Brian
  2. #12
    4,563
    Quote Originally Posted by Brian Corrigan View Post
    Jay,
    Brian
    Brian I used 2 spaced 3/4" apart and it has worked out just right for me.
    A Turn N Time
    Frog Pond Guitars
  3. #13
    Mar 2010
    Maplewood, NJ
    78
    Thank you, Yoda!
  4. #14
    Mar 2010
    Maplewood, NJ
    78
    Does it sound like I'm in my shop today?
    And the questions just keep coming...
    That 1/4" notch on Boards A, C & D, it's 1/4" by what exactly? No dimension is given. The full scale drawing is not exactly what you'd call precise. Could be 2". Could be 1 15/16."
    Since I can't tell how critical it's likely to be before I try to assemble the pieces, it would be nice to know.
    Thanks again,
    L. Skywalker
  5. #15
    4,563
    Thanks again,
    L. Skywalker
    Brian look at the drawing on page #3 see the line going all the way through there by part "D" that's where you cut too look on the video and it shows it also.
    I screwed mine together and then made the cuts on the table saw as an assembly and it worked real nice. Will post picture of it later today.
    A Turn N Time
    Frog Pond Guitars
  6. #16
    4,563
    Here are some more pictures of the Bellows
ID:	45452 Click image for larger version.
ID:	45453 Click image for larger version.
ID:	45454 Click image for larger version.
    This shows where to cut for the 1/4" ply on the end
    A Turn N Time
    Frog Pond Guitars
  7. #17
    Mar 2010
    Maplewood, NJ
    78
    Great shots, Jay... and again, very helpful.
    Is that oak you used for the stiffeners?
    The cut for the 1/4" ply... dado on the tablesaw?
  8. #18
    4,563
    No its Maple.
    I just used the regular saw blade and the miter gauge with a tall fence and clamped it to it on end made the cut then lowered blade and made the other cut with it setting on edge
    Last edited by Vaughn McMillan; 05-18-2010 at 09:36 PM. Reason: Fixed broken [QUOTE] tag
    A Turn N Time
    Frog Pond Guitars
  9. #19
    5,268
    "I just used the regular saw blade and the miter gauge with a tall fence and clamped it to it on end made the cut then lowered blade and made the other cut with it setting on edge."
    What???!! I'm lost!
  10. #20
    4,563
    What???!! I'm lost!
    I'll set it up and post a picture
    A Turn N Time
    Frog Pond Guitars
  1. Tom's 31 note organ build
    Last Post: 12-11-2017, 05:41 AM
  2. Organ build
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 01-21-2017, 06:55 AM
  3. Too Good To Hide In The Organ Build Forum
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 05-24-2013, 02:02 PM
  4. Re:Organ Build Thread Started by Carol Reed
    Last Post: 11-11-2012, 01:36 PM
  5. The FWW group build Organ
    By Jay Caughron in forum General Woodworking Q&A
    Last Post: 04-26-2010, 01:33 AM
