Page 6 of 41 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 406
Thread: New Organ Build Topsy 3
  1. #51
    8,019
    Quote Originally Posted by ted heid View Post
    Have no idea what a golf trolley motor is. Any more info or a pix on how he did it?
    Ted, he probubly means a golf cart motor, you know those brits talk funney.
  2. #52
    3,909
    Yeah but its not the kind you ride on its the ones that have a motor on them and look kind of like the ones you pull.
    Jay
    A Turn N Time
    Frog Pond Guitars
    "Peace is that brief glorious moment in history when everybody stands around reloading".--Thomas Jefferson
  3. #53
    8,019
    here is a link to ww grangers motor selector that might help you guys locate a motor for this build.
    darn it can't get the link to work. just go to their web site and select motors, then select find a motor by application then gear motor.
  4. #54
    3,909
    Gear motors
    Cant afford any of those Don but check this site out
    https://www.surpluscenter.com/sort.a...dc%20gearmotor
    A Turn N Time
    Frog Pond Guitars
  5. #55
    3,909
    Bellows install and Acc windchest
    Well I figured I had better show what I have been up to.
    This is the Bellows install in the case. I ended up having to lower the end with the metal bracket to get enough clearance for the acc windchest (take note for those who are building.
    This is the start of the acc windchest.
ID:	46402Click image for larger version.
    This shows the acc windchest installed in the case and after lowering the Bellow on the crank end.
    A Turn N Time
    Frog Pond Guitars
  6. #56
    3,909
    Errors on drawing
    I need to let some folks know of some errors I have found. I have talked to John and changes are coming just want to give those building and watching here the heads up.
    The Accompaniament pipes on pg #6 the C# pipe internal depth should be 1-7/32 not 1-7/64
    On pg #7 the measurement for drilling "A" shown at the bottom of pg should be 1-3/4" NOT 1-1/4" shown.
    On pg #8 for the Melody Bourdons. The internal depth starting at "B" & "C" pipe should be 11/16 NOT 5/8 and the Width should be 5/8 (nothing shown)
    Hope I have got these to you in time.
    A Turn N Time
    Frog Pond Guitars
  7. #57
    3,909
    Building Pipes
    Well the pipe factory is OPEN
    Working on the 44 Bourdons
    These are the 12 Accompaniament pipes
    A Turn N Time
    Frog Pond Guitars
  8. #58
    May 2009
    Poway, CA, near San Diego
    154
    Jay,
    Could you clarify this please?
    "On pg #8 for the Melody Bourdons. The internal depth starting at "B" & "C" pipe should be 11/16 NOT 5/8 and the Width should be 5/8 (nothing shown)"
    So, B through E (starting at the top of the list) are 11/16 int. depth and 5/8 int. width?
    Bob
  9. #59
    3,909
    Bob
    Yes that is right John was in the process of changing it and got side tracked.
    I cut "D#" & "E" 5/8" and 1/2" Im not sure if thats right or not but it what I did. John said what is wrote down was what the pipes measured.
    Jay
    A Turn N Time
    Frog Pond Guitars
  10. #60
    May 2010
    milwaukee wisconsin
    64
    bellows testing
    Case is done and ready to test bellows pressure and do adjusting but: I don't see how the fitting that goes on the bellows is made, When that is figured out then is the water gauge connected to it and the main reservoir hole closed off?
