Results 1 to 7 of 7
Thread: Tips on sharpening lathe tools?
    Charlotte, NC
    1,487
    OK, I have the lathe and, on Don's recommendation, I have picked up the HF lathe. Any suggestions on sharpening the tools? What angle should the bevels be? I have the WC slow speed grinder with the standard wheels, 60 & 120. Do I need to take it any further like I do with my bench chisels and plane irons?
    Hep me, please!
    Houston, TX
    363
    Ed,
    I think a number of people use 80 gr. but I like the 120 myself. There is an article in one of the WW mags. in the last few months by Mike Mahoney on sharpening bowl gouges that you might find helpful. I attended a school locally that Mike taught and while I find his grind angle a bit steep (40*) his freehand sharpening method pretty much negated the Wolverine with better results. Most tools, I think, have a decent approximation of the proper angle (except gouges) and it is just a matter of matching the angle and giving it an edge. Don't get compulsive over sharpening gouges. If you do you will spend more time sharpening than turning. It's plenty good off the wheel. You might want to give it a little bit extra on the finishing cuts.
    30,224
    Like Cecil, I pretty much stick with the 120 grit wheel, and in most cases I don't go any finer. I just use the chisel straight off the grinder. I've also got a little diamond hone that I use to touch up the edge between trips to the grinder.
    As for the angles, I pretty much try to keep things at about the angle they came from the factory with, although I'm not afraid to experiment and try something a bit different, especially on gouges. Part of the reason for using the HF tools to start is that you can afford to grind on 'em pretty often as you experiment with things like bevel angle.
    A lot of guys get good results free-hand sharpening, and a lot of us use a sharpening jig like the Wolverine. (I use the Penn State knock-off of the Wolverine, which gets the same end results.) There have been a number of folks who made their own jig, often using the Wolverine-style jig for inspiration.
    San Antonio, Texas
    765
    Ed, I posted an answer to a similar question here.
    San Antonio, TX
    57
    Dario
    http://www.aoturnings.com/
    15,811
    Billy thanks for the tip in my grinding thread!
    Ed, got to the Oneway site and look at their sharpening videos, you can lean a lot by watching them.
    Charlotte, NC
    1,487
    Interesting comments Billy. I'll have to check on the wheel situation.
    Vaughn & Cecil, thanks for the info
    Dario, that's an interesting set up
    So much to think about...so little time!
  1. Sharpening Carving and other tools
    By Rob Keeble in forum Carving
    Last Post: 02-25-2016, 03:08 PM
  2. Belt sander for sharpening lathe tools?
    By Bill Nicklaus in forum General Woodturning Q&A
    Last Post: 08-09-2012, 11:11 PM
  3. jig for sharpening wodd turning tools
    By Bob Nagel in forum Jigs and Fixtures
    Last Post: 03-07-2012, 07:33 AM
  4. Sharpening carbide tools
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 12-28-2011, 05:30 PM
  5. Scraper Sharpening some tips from Czech Tool
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 07-05-2011, 10:39 PM
