Results 1 to 9 of 9
Thread: Sharpening bowl gouge on the cheap
    San Antonio, TX
    57
    Not quite wolverine nor varigrind ...but the results work.
    My cost is about $3.00 so my setup will never win any beauty pageant but it works. Here is a freshly re-ground bowl gouge from a standard/regular shape to an "Ellsworth" grind. I didn't cut the tip too much (to save some steel) so there is a bit of double bevel still. It will be gone after a few trips to the grinder.
    The base is a scrap wood (from milling pen blanks) screwed to a block of another scrap piece. The end received a few mounting pieces at various height and distance from the end (I have 3 right there). The dimples were drilled so the jig won't slip.
    The ala "ellsworth jig" is again made from a scrap wood drilled through. The locking mechanish is an eye bolt with a metal insert on the wood so it will not destroy the wood easily. The post is just a long lag bolt and I just cut off the head.
    Hope this helps others who plan on making their own jig.
    I am using a 6" high speed grinder so it works with that. It can easily be adapted to 8" also by making the mounting part on the end higher by an inch.
    Dario
    http://www.aoturnings.com/
    Charlotte, NC
    1,487
    Dario, I don't yet know what I am doing, but that looks like a good setup!
    15,815
    Looks good works great!
    I'm learning (again) how to sharpen my gouges, I read a good article in the AAW magazine that really opened my eyes.
    As a freehand grinder (and not a very good one at that) I are interested in manufacturing such a set up as I haven't mastered the bowl gouge yet. Got and dimensions to share? Please
    San Antonio, TX
    57
    Bill,
    I will check if I still have them and post this weekend.
    Most likely, best I can give you will be photographed scribbled sketch.
    You can start here... http://www2.woodcraft.com/pdf/77B61.pdf
    I also had a plan shared by a fellow woodturner (Jean Michael from Canada)...he passed away and I am not sure if it is ethical to share his plans. Personally I think it is okay since he did it to me and he asked nothing for it. A great guy I surely miss.
    Dario
    Thanks Dario, the PDF from Woodcraft specificly says use for 5/8" Bowl Gouge Only.... Mine are 1/2" and 3/8"
    Is that because the hole in the Jig? If I use a 1/2" hole and another with 3/8" hole respectively it should be OK, (?) Agree?
    Guess the only question is how long the pivot point rod. I guess that will appear obvious when I construct the other pieces.
    Thanks, again.
    San Antonio, TX
    57
    Bill,
    You are right it is only the hole. Mine can handle up to 3/4". I will email you something as soon as I find it.
    Also check this http://www.aroundthewoods.com/sharp.shtml
    Dario
    San Antonio, TX
    57
    A great reference..
    http://www.atbq.qc.ca/jm2/
    Dario
    15,815
    Great info in the links, thanks so much for those!
  1. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
  2. Sharpening-Thompson Gouge-Jet Wet grinder
    Last Post: 04-11-2009, 12:51 AM
  3. Sharpening a Gouge
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 04-08-2008, 01:58 PM
  4. Need a new Bowl Gouge
    Last Post: 05-05-2007, 09:18 PM
  5. Bowl Gouge
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 02-22-2007, 11:15 PM
