Results 1 to 7 of 7
Thread: handling a handle
    11,826
    handling a handle
    Here is a pusher I started making several months ago. The shape was inspired by a saw someone posted here.
    As you can see, it is unfinished.
    My router bits are just too big to make the sharp turns and get through small spaces.
    I bought a set of 1/8" shank bits but they are junk. Don't understand why. The set of ten cost $12.00. That makes them over a dollar each, I sure expected better.
    Other than getting out the files and rasps what do y'all suggest for rounding the edges on this handle pusher to be?
    13,437
    It's a nice looking pusher, but the gap under the handle would make me nervous if a kickback occurred and made the handle snap.
    Might consider using a plywood or layering your own with grains crossing for strength
    Reminds me of an old girl friend... Deli Kate
    Althought the design is retrospect to some of the older and finer handsaws of the past. Perhaps you are a bit too fancy. (for your own good) I designed mine with the handle assuming a Plane's Tote.... I find it easy to grasp, my hand is NOT confined in the handle should a major kick occur, that positioning provides a downward push as well as forward.
    I thought of a saw handle style but selected the Tote in stead. Good job, though We each have our preference.
    As for the routing, you should be able to cut the inside of the handle and such but the pointy ears will have to be filed, it appears. Notice on an old saw handle, the ornate parts are simply shallow roundovers.
    11,826
    It is two parts, lower ash, upper walnut. The lower is held on with dowels. But, you make a good point. I'm going to run another dowel up from bottom right through that handle. I believe that will make it very sturdy.
    12,247
    Frank i am with Darren and Bill on this one. Dowel or no dowel I would use it as a nice wall souvenier. Sorry but it looks dangerous.
    11,826
    Oh, well.
    Mebbe I can find another use for it.
    Westphalia, Michigan
    955
    Gee Frank, if it was made out of curly maple I would think a muzzleloader craftsman made it.
  1. Handling Winter
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 01-07-2014, 11:32 AM
  2. Handling glue squeeze out.
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 12-27-2012, 03:26 PM
  3. New Handling of Links
    By Cynthia White in forum Site Questions and Test Posts
    Last Post: 11-21-2011, 05:47 PM
  4. Handling logs
    Last Post: 11-10-2010, 02:26 PM
  5. Handling the Heat
    Last Post: 07-27-2007, 06:55 PM
