Results 1 to 10 of 19
Thread: Vibrating jointer - Off to see the wizard
    Constantine, MI
    7,891
    My DJ-20 has a vibration that is getting worse. I've opened it up and it seems that the source of the vibration might be the belt. However, the belt seems in good condition. What could be causing the vibration? Belt too old? too tight? Too loose? Misaligned?
    I don't see anything wrong with the sheaves and the motor runs smoothly - no bearing noise, etc.
    www.wrworkshop.com
    Sep 2007
    Plainwell, Michigan
    4,857
    Did some saw dust or something get lodged between the belt and pulley
    13,361
    Everything ok with the cutterhead? Nothing loose there I trust?
    Could always try one of those link belts. I used one on my bucket mortar mixer and it works pretty well there. They are supposed to help eliminate vibration, so if it's the belt, that would be a quick fix.
    Constantine, MI
    7,891
    OK - Dug a little deeper. Removed the belt, still vibrating. Removed the sheave, motor runs smooth. So, I'm guessing its the sheave. Now, can't see any damage and there is evidence it has been balanced. So - what's next? Can I take this someplace to be balanced again?
    www.wrworkshop.com
    Look in the yellow pages for electric motor rewind shops. The have balancing equiptment...
    11,833
    I don't know how the sheaves are balanced. But, if weights were used, it may be possible a weight fell off.
    Have you swept the floor recently?
    17,474
    you havnt seen his shop have yu,, its never dirty for more than a day.
    Constantine, MI
    7,891
    OK. Another bit for the craniacs among us.I replaced the belt and took the sheave (which is balance by taking material away, not adding to - so, no need to sweep the floor) to the machine shop and checked the balance. Not perfect but within tolerances. I realigned everything and tensioned the belt and it still vibrates.... but only under load. As soon as the power is turned off the vibration disappears and it spins down quietly.
    So, all of you electrical wizards out there - could I have wired it incorrectly? It's single phase 220. Could the winding be at fault?
    Added - I did a little research on the web and found a number of references to rotor issues if the vibration is only when power is applied. Also looked at some replacement prices. Yikes.
    www.wrworkshop.com
    N.E. Arkansas
    374
    In my experience some vibration issues may be solved by making sure the pulleys are properly seated and the set screws are tight. Sounds like you have taken care of that on the motor. How about on the cutterhead?? I know of nothing that would cause that kind of vibration that is a wiring issue. If the motor spins the correct direction, it's wired right.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    My $o.02 worth . Bearings? loose bearings will show up under load where it seems smooth otherwise. Could be bearings in motor or in the cutter head. Could be a dry bearing from the dust etc. Disconnect (and all those safety issues) turn (spin) and if you feel ANYTHING, there is a problem...
    Could be belt: I'm not sold on link belts but I do like segmented belts. they are much more flexible than standard belts. If it has been a while sense last use, some belts get stiff in time.
    Real question is if you can feel the vibrations on the tables or are you talking about shaking the plaster type of vibration. Fast or slow? Slow, I would look at the belt, as it indicates a slap. Faster points to a rotating object.
    My thoughts on the matter. Will be interesting to find the answer.
  1. So am I "The Wizard"
    Last Post: 03-24-2011, 07:15 PM
  2. New (to me) #7 Jointer
    Last Post: 10-30-2009, 02:58 PM
  3. Lumber Wizard III--does it do the job?
    By Ron Jones in forum General Woodworking Q&A
    Last Post: 10-06-2009, 12:35 AM
  4. Beall Pen Wizard
    By Jonathan Shively in forum Turning Tool Questions and Show & Tell
    Last Post: 12-25-2008, 01:17 AM
  5. Don Herbert (Mr. Wizard) dies at 89
    By Jason Beam in forum Off Topic Discussion
    Last Post: 06-18-2007, 06:57 PM
