inlaying is not for me.
I patiently made a jig to use my router and a bushing, and a 3/4 inch dado bit.
I practiced on white oak, to get a feel how it would be, then I carefully place and clamped the jig down onto the better side of the table top(first mistake, should have used the second side),used the plunge base and only went down 1/16th or so, and my lengthwise cuts were great, but when I went to connect them, the groove was off just a bit, but a bit meant I had to take out a chisel and do it by hand.
I was about to go up and get out my 3m paper to hone a chisel so Id have a nice sharp one, the marples are due for sharpening. They cut well, but I know its time.
I took one of the Ashley Isles chisels Ive never used, and it tapped right into the white oak easily.
I carefully clamped down a straight edge to square off the ends and bring up the channel to size(now the ends are a bit larger than the long channels, but I wasnt concerned about that)
I cleaned it all up, and it looked ok. I got picky, I carefully used the chisel the last time, and chipped off a tiny, maybe 1/16 or less of the edge.
So thats that. What I needed to clean up the channel is something Ken showed me at the show. A router plane, would be perfect for inlay channel cleanup.
Anyway, not that pleased and about to abandon the entire inlay attempt, I said what the hoot, might as well. I should not have. This isnt easy for me.
Kudos to all you guys that inlay and all that stuff. PUtting in a stripe of mahogany turned out to be 20 times harder than I had expected.
I botched the entire job. I was so careful sizing up the pieces, fitting end to ends, cutting with sharp razor and straight edges. eh.......I dont have the hands, the eyes, or the main thing, the talent and experience to do this.
Ill flip the table top and use the second side. This was an experiment, so I wont lose sleep over it.
I put some wax paper over the inlay strip, put a particle board over the entire surface, and put my planer on it to weigh it down.
Wont be no pics of that mess, but Ill get to see just how crappy my inlay work is.
I spun a handle on my lathe. I dont use the lathe anymore, so besides a pen or two every couple months, I figured might as well use it for something.
Took some scrap white oak and mahogany, this is what I came up with, wife said ok, so its ok with me.
Im not 100% lately, my therapy cant come soon enough tomorrow. Im off for the week.
btw, originally, I was going to cut 2 squares of mahogany and lay them into the top, and I believe that would have been much easier with a template of the squares. I should have stuck to that plan.
