Results 1 to 10 of 17
Thread: handrail construction question
    Oliver Springs, TN
    1,726
    A guy I work with is wanting to make a handrail from some oak he has. It's 2" thick by 4.5 wide. He needs the total length to be 16' long. He has one piece that's 12' and another that's 6'. He asked me how I'd join the two together to get the total length. I thought about maybe pocket screws but use some that are about 2 - 2.5" long. I don't know if that would leave a gap at the top. I also mentioned dowels but gluing the two sections together might be a problem. Would you cut the two ends at 90 or 45 degrees?
    How would you do this?
    John, you want to make a scarf joint. You cut both peices at a shallow angle.
    17,474
    john i believe don has the right answer here. have seen a few done that way. and by doing that you will have the strongest joint you can have and can also maintain the position better than attempting a dowel set up..he will probably have to feather out the transition between the two.. with some sand paper or a scraper.
    Dec 2009
    Kemah, Tx. - Houston Suburb
    95
    Another vote for a scarf joint. Usually a 12 to 1 scope is used. Scarf joints are commonplace in boat building, especially for making 12' plywood from 8' plywood boards.
    Oliver Springs, TN
    1,726
    It looks like a scarf joint is the consensus so a scarf joint it is.
    How would you cut the angle? The 12 footer is one heavy sucker!
    Tony, when you say 12 to 1 since the board is 2" thick would that be a 24 inch cut?
    Jeff Horton shows a scarfing jig rig in this post.
    Oliver Springs, TN
    1,726
    I think I'm gonna have to back up and punt. Jeff's jig would be great except I have to make the cut in the 4 1/2" direction. I can't use the table saw.
    Do y'all think the cut could be made on the bandsaw? Would it be accurate enough?
    John, if you make a sled it should.
    13,361
    Those are going to be some long unwieldy pieces to move around.
    Couldn't you use an angled fence and use a circular saw?
    5,172
    Rough cut on the band saw and hand plane into a perfect fit. Fastest, easiest, cheapest. What's not to like?
  1. Frameless construction question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-09-2013, 08:27 AM
  2. Cabinet Construction Question(s)
    By Mark Kelly in forum General Woodworking Q&A
    Last Post: 09-29-2011, 05:08 PM
  3. construction question-
    By allen levine in forum Carpentry and Construction
    Last Post: 05-14-2010, 01:48 AM
  4. New contender for Dumbest construction question prize for 2007
    By Bill Lantry in forum Carpentry and Construction
    Last Post: 11-23-2007, 01:41 AM
  5. Pole frame / Post Frame construction question
    By Lincoln Myers in forum Carpentry and Construction
    Last Post: 10-19-2007, 10:54 AM
