Results 1 to 10 of 16
Thread: sharpening stations
    17,475
    sharpening stations
    how about yu showing us your sharpening areas,, pics are preferred.. i am in the middle of gettin one together, been going form this to that and back here for the last few years and after seeing bill satko's i need more organization in that area.. got some ideas in my head but am always open to suggestions.. so show us your sharpening station and give us any insight as to how or why yu did it that way..
    9,077
    My scary sharp plates, MKII jig and WS3000 all set on a shelf inside a cabinet near the bench. The WS3K is bolted to an organizer/stand that gets clamped via bench dogs at either vice position.
    The SS plates just rest on a piece of that rubbery shelf liner to keep them from skidding around. (old picture showing my old C-man saw in the background ).
    I leave the stuff out if I am doing a lot of work that will require touch-ups as I go. I can set it all up or put it all back to clear the end of the bench in just a few moments. I generally like to have stuff close at hand but these items are used just intermittently enough to not warrant a dedicated station in the shop. This could change; YMMV.
    3,134
    A few ideas tall enough lockable swivel casters to give toe clearance a stainless top (or at least a laminate top) & a non skid mat with a place to hang it to dry. I like to use the mat to set my water stones on. (purchase at my favorite Grizzly store)
    http://grizzly.com/products/Router-Pad-Tan/G1530
    I don't have room for a hand sharpening station & am not sure how I would construct it because I like to stand or sit while sharpening depending on what I am sharpening the amount of time spent & or how my back feels.
    The more I think about it maybe 1 drawer for water stones & jigs with 3 solid sides & one open with the drawer with a wide bottom edge to mount the casters on. this would allow being able to sit on one side for hand sharpening & to rotate the stand to the opposite side of the stand & use the powered sharpening devises.
    I use my Worksharp & regular grinder to speed the process along toward the final end. I have 2 bench grinders on a board bolted down to a small wall hung bench & rotate one or the other grinder forward depending on the job at hand. If I had the room I would also have a strip sander.
    13,363
    Getting ready to make one too. Really want to have one place for all my sharp things, and things to make things sharp...
    17,475
    glenn what are your grits on, i think they are dmt stones you show in the 2cd picture?
    11,833
    When I started putting my shop together I realized quickly I needed to make the best use of the limited space available.
    I decided to use 'islands' wherever possible. This was the first, my sharpening island. It shows a 1" belt grinder, 8" old Craftsman grinder, EZ Sharp knife sharpening wheels and my new WoodCraft sharpening grinder with a Wolverine system.
    It once had a large wet wheel. But the wheel cracked, plus I almost never used it.
    Yep, that's dust on everything. Fact of life in my shop.
    Attached Thumbnails Attached Thumbnails sharp station 1.jpg   sharp station 2.jpg
    17,475
    what you got on the two wheels to the left and why the belt sander?
    Larry, many of the spinney folks use the belt sander for touching up there turning tools, I suspect that is what frank uses it for. See if youd get a lathe you would know these things..
    3,134
    He's dizzy enough without a lathe, ya think!!!!
    Besides that if he got a lathe he might end up bald faced if he caught it in the lathe.
    Then we'd end up calling him Harry..............
    11,833
    Those two wheels are both hard cardboard. They are the EZ Sharp system for knives and such. The black one is coated with a grit that comes with the wheels. The grit is coated with hard wax. The other wheel is charged with white rouge.
    Sharpen on the black grit wheel, only takes seconds. Then hone the edge on the white wheel. Works great. Kinda messy to recoat the black wheel but that's not needed often.
    The 1" belt sander was one of the first bench tools I ever purchased and my first Grizzly some 20+ years ago. I had intended it for sanding irregular shapes, like gunstocks. I took out the platen behind the belt so it would flex with the shape. Didn't work. 1" is too narrow making it too easy to cut grooves in your work. But, I still find it very handy for other things, like sharpening augers and brad point bits and other sundry stuff. The 8" sanding disk is frequently used also even though I would like to have a much bigger one.
  1. My <$10 sharpening jig
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2016, 11:41 PM
  2. sharpening?
    Last Post: 07-31-2011, 03:25 AM
  3. New Sharpening Jig
    Last Post: 03-01-2009, 05:05 PM
  4. Sharpening Stations?
    By Randy Privett in forum Turning Tool Questions and Show & Tell
    Last Post: 10-20-2007, 02:55 PM
  5. Timers for battery charging stations...
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 12-28-2006, 02:19 PM
