Results 1 to 10 of 20
Thread: Plywood Edgebanding
    Pennsylvania
    361
    Plywood Edgebanding
    I'm going to be throwing together a bunch of plywood cabinets soon and I'd like to edge band them. Two questions:
    Does anyone have a good source for edgebanding? The closest WW store to me is 45 minutes away so I'll probably order some online. I'm assuming I won't find this at the borgs but maybe I'm wrong.
    What is the quickest/easiest way to trim the edges? I'm not opposed to spending a few bucks on a tool that will help me get it done quickly. Jig ideas will be considered as well. Would this be a good excuse to get a Bosch Colt?
    688
    Hey Rob,
    You might check out HD, some stores do carry edgebanding, but not lots of variety of species. There is a tool you can buy for about $10 that will trim the edges. A colt would work fine, but you will need to provide some support to keep it level.
    The Heart of Dixie
    4,268
    I have found Birch edge banding at the Borg and even local Hardware stores. Just used some last night on the last of the shelves. I just take my knife (a razor knife would be better) trim the excess and then a block plane to finish it up.
    Custom built boats and Kits
    I have bought maple edge banding from this company (http://www.oakwoodveneer.com/prices/...ge_glued.html). Good product, good service. Cost might be less than the Borg given the quantity you may need.
    Mike
    1,289
    Quote Originally Posted by Jesse Cloud View Post
    Hey Rob,
    Jesse,
    What tool would that be? Are we speaking of the iron on banding?
    I am about to do pretty much the same. Bunches of open shelves in the new shop. I haven't used banding either. I was thinking of just using oak strips for trim off of some pallet wood I have around. If the banding will really work ok, I would use it in quite a few applications.
    Thank you
    Don
    San Diego
    11
    I've used Fastedge in the past. Apply it with a hard roller, no heat. Got it from McFeeley's. Get the trimmer - it's worth it. It works with various stock thickness and trims both sides at once.
    Mike
    If you can't make it perfect, make it adjustable!
    1,289
    Thank you Mike.
    Don
    15,815
    The stick on banding or the hot melt banding works fine, and the tool is a really good spend, IMHO, but this stuff is fairly fragile, and the glue does eventually give out, then a bump and it all comes off.
    For stuff around the house, that does not take any abuse, I'm thinking a shelf with towels on it or such, it is fine, but for the workshop........?
    I'd rip off some 1/4" thick strips of wood and glue and nail them, they will take a lot of abuse and still be there.
    Just my 2 yen's worth
    Montclair, NJ
    95
    15,815
    Quote Originally Posted by Craig Feuerzeig View Post
    And your point is Craig?
  1. Plywood (from where)
    By Paul M Cohen in forum Carpentry and Construction
    Last Post: 05-30-2008, 02:38 PM
  2. Arauco Plywood
    By jim crockett in forum General Woodworking Q&A
    Last Post: 05-16-2008, 07:20 PM
  3. Can your plywood do this??
    Last Post: 04-02-2008, 06:48 PM
  4. Bamboo Plywood
    By Erik Monson in forum General Woodworking Q&A
    Last Post: 02-26-2008, 03:44 PM
  5. Plywood
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 03-21-2007, 02:29 AM
