Results 1 to 9 of 9
Thread: My newest challenge--Part 2 The Frame
    Feb 2010
    Midlothian,Va
    116
    When I first took on this project I was going to use white oak for the woodwork, but after talking to the owner and getting permission to also do the original paint job I decided to go with the materials that were used in the original—maple for the frame and poplar for the box. After sizing all of the frame components to 1 3/4” x 2 1/8” and cutting to the proper lengths I began with turning the 2 small handles.
    There are a lot of mortise and tenon joints used to hold the frame together so I went ahead and set up a tenoning jig to use on the bandsaw. Very simple set-up really. Making absolutely sure that the blade is set to true 90 degrees to the table is critical to using this jig to make tenons. I started by making a small sled that rides in the miter slot which is used to guide the work piece through the blade for the shoulder cuts and an adjustable clamp- on block to use as a reference point for the length of the tenons. I also made a stop block that clamps to the fence that is used to get the depth of the cut. After making a sample tenon to use as a reference I can now set the fence with the stop block and cut all of the tenons to the right depth.
    Here is the set-up for cutting the shoulders.
    Perfect every time
    After all of the tenons were cut and all of the mortises were drilled and chiseled I drilled all of the hardware mounting holes, and did all of the rabbeting on the router table using the original pieces of the frame as a reference.
    Here are all of the pieces for the frame.
    Here is the dry fit frame
    Here is the frame with most of the mechanical pieces set in place.
    On to the parts for the box for the Hocking Valley Corn Sheller.
    Mike
    "why buy it if you can build it"
    www.midlothianwoodworks.com
    My CustomMade Page
    http://www.custommade.com/by/mikemathieu
    Sep 2007
    Plainwell, Michigan
    4,857
    This build for some reason really has me captivated, looking real good so far Mike
    10,604
    This is a great project
    will you SHOW me how to use it ? looks good
    Jan 2010
    UPlengen - try and find that ;-)
    23
    an interesting project, make sure to update regulary please.
    Karl
    You name it, I'll butcher it !
    4,552
    What a great project Mike
    A Turn N Time
    Frog Pond Guitars
    Feb 2010
    Midlothian,Va
    116
    Thanks everyone for the comments. This is a really fun project. I found a photo of a sheller just like the one I'm working on and hopefully mine will look like this when I'm done.
    Mike
    My CustomMade Page
    4,552
    We used ours to hull walnuts. They are a fun old tool
    A Turn N Time
    Frog Pond Guitars
  1. My newest challenge
    By Mike Mathieu in forum Flatwork Project Showcase
    Last Post: 03-13-2011, 03:33 PM
  2. My newest challenge Part 4--Mission Accomplished
    Last Post: 05-23-2010, 03:18 PM
  3. My newest challenge part 3-- The Box
    Last Post: 05-21-2010, 03:25 PM
  4. My newest challenge
    Last Post: 05-10-2010, 05:34 PM
  5. Picture frame - part II
    By Niki Avrahami in forum Flatwork Project Showcase
    Last Post: 03-19-2008, 02:21 PM
