Results 1 to 8 of 8
Thread: plane mallet
    Central NY State
    3,374
    plane mallet
    Well, I've been hankering for a nice little mallet to adjust plane irons and other things without damaging the metal, so I made this the other morning. The handle is cherry, and is oval in cross section. The head is a piece of rosewood that I cut out of a larger block. Should do the job nicely.
    30,002
    That looks great, Ken. Did you make the oval handle on the lathe or with edge tools?
    Central NY State
    3,374
    Thanks Vaughn. The answer to your question is yes.
    I cut the handle blank out as a rectangle, turned the outside curves, then with it on the lathe [not spinning] blended from the flats to the outside curves.
    12,243
    very nice Ken. Has it got enough weight to make the blades move in a wood plane?
    11,825
    Nice. A blend of spinny and Neander.
    Central NY State
    3,374
    I guess it depends how hard I hit it, so far, so good. The longish handle allows for a good bit of momentum.
    13,353
    Very nice Ken.
    Been thinking about one of those myself.
    Did you drill the hole in the mallet head before or after turning?
    Central NY State
    3,374
    Hole drilled after turning. I used a shop made V block and my drill press.
  1. Keyaki Mallet
    Last Post: 10-31-2012, 01:26 PM
  2. Mallet Madness
    By Ryan Mooney in forum Lathe Project Showcase
    Last Post: 09-01-2012, 08:58 AM
  3. First Turning - Mallet
    By Rich Aldrich in forum Turning Tool Questions and Show & Tell
    Last Post: 03-28-2010, 10:37 PM
  4. A couple mallet's
    By randy street in forum Neander Tool Questions and Show & Tell
    Last Post: 12-17-2009, 03:43 PM
  5. first mallet
    By Mark Kosmowski in forum Lathe Project Showcase
    Last Post: 11-07-2007, 03:59 PM
