Les, do you find it easy to make minor adjustments to the mitre stops? I notice that this saw does not have a micro-adjustment like the Bosch. If I need to go to 46 or 47 ... is that easy to do?
Do you have any other complaints / info about the saw? It`s nice to find someone who has the exact saw and can give some hands-on advice.
Mine does have the micro-adjustment, and works great. I may have a different model
it also has the laser, and digital readout. I'm sorry if I mislead you, but its a great saw, and I would do it again.
most mitersaws are adjustable to 90º.....the presets are a given from that point, so check 90º and your common angles should be spot on seeing as how all of these machines are cut on large cnc mills.
