Results 1 to 10 of 15
Thread: 15" planer feed trouble
    17,470
    i have a stationary 15" planer top cutter ,top motor variety. i was running some lumber threw it yesterday and i had to push it threw to much.. it was dry hickory and wasnt taking that heavy of a cut.. any idea why the feed roller is not grabbing it and pulling it threw on its own.. i have use other 20" models and you stick in and it grabs it and its going on its own for the most part unless you hit a thick spot where it wasnt cut uniform.. is it because hickory is a HARD wood and it doesnt grip it well???
    Constantine, MI
    7,887
    Rubber or metal infeed roller?
    www.wrworkshop.com
    17,470
    ribbed metal, rennie. the ribs run parallel with the roller spaced approx. .125 cntr to ctnr
    4,551
    Wax the table that will help some. You can also have to much down pressure on the feed rollers and that will cause it to stop feeding it's kind of backward of what you would think. Normal reaction it to put more down press and that can be the wrong way to go making the problem worse.
    I always had a block of paraffin wax and rub on the table that help alot and will not cause any finish problem in the wood.
    A Turn N Time
    Frog Pond Guitars
    17,470
    will try your wax job jay and see what happens!
    Larry, are the blades sharp. I know I had the same problem on my little 13" and when I put sharp blades in the problem went away. I was planning hard maple.
    13,353
    When were the blades last sharpened? I know on my Dewalt, the sign that it's time for new blades is when it stops feeding right...
    13,353
    Oh, and when I'm working with something hard, like maple, the blades get dull, fast...
    new york city burbs
    10,184
    almost every time I have a feed issue on my planer, I wipe down the rollers carefully with acetone or mineral spirits, lightly, clean them good though, and give 2 coats of butchers wax to the surface, and the wood feed through perfectly.
    clean it up, it will probably run much better, I think if the blades are dull, the feed would be good, the cutting would be poor.
    I thought so to Allen but I found out differant.
  1. Planer feed rollers
    By Tony Baideme in forum Old Iron
    Last Post: 09-04-2013, 01:30 AM
  2. Having trouble fing a good "used" lathe.
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 06-03-2009, 06:07 PM
  3. 12" x 12" Auto Planer Wood Planer
    By Jim Burr in forum Hot Deals
    Last Post: 11-13-2008, 02:18 PM
  4. Parks No20 Planer Feed Problem
    By Doug Bury in forum General Woodworking Q&A
    Last Post: 10-13-2008, 09:13 PM
