- Constantine, MI
I thoroughly cleaned my shop today (no laughing Larry). As I was leaning back admiring my work for a moment I noticed that my band saw table seemed to be tilting towards the front. Now I've always known to check the table for square from the side of the blade, but I never thought to check front to back. It so happens that I changed the position of the saw when cleaning and was able to look at it from a new angle.
There are adjustment screws to set this right, but before I do any major changing I wanted to query the collective mind of the forum. I assume the table should be square to the front to rear axis of the blade. Is this correct?
Second question. I need to remove, clean, and lube my guide bearings. What do you use?
