Results 1 to 9 of 9
Thread: Steam Bending Question
    Dec 2008
    Portland, Oregon
    1,898
    I need to bend some pieces for a project, I remember Leo Vosine had a post that he used charcoal for the heat, I tried that, and got the water boiling good, but didn't get much steam up to the wood.
    Should I be using a bigger hose from the pot to the pipe? It's 3/4" inside diameter. I'm going to change to using either an electric hot plate or a propane camp stove, the charcoal didn't last as long as I liked.
    Any help appreciated.
    Jesus was a Woodworker
    May 2009
    Syracuse, Nebraska
    669
    Dan, at first glance, it appears there is no hole on the other end of your steam chamber. The steam needs to flow through from one end to the other. Just a small hole to let it vent. Maybe 1/2 inch.
    Dec 2008
    Portland, Oregon
    1,898
    Actually there is one right behind the cap (the one without the hose) it's only about 5/16" I'll enlarge it when I re-try it. Thanks for the tip!
    17,470
    havnt done it dan, but chuck thiots has.. look at his mug thread.. i think he used a camp stove-propane..
    NH
    4,005
    I used a propane burner made for cooking turkeys or other big pots of stuff.
    Stupid hurts.
    NH
    4,005
    Looking at your set up I would say that your heat source is the problem. Hotter fire for a harder boil, harder boil = more steam The size of your vent hole should be fine.
    Stupid hurts.
    Dec 2008
    Portland, Oregon
    1,898
    Thanks Chuck, I'll find different burner.
    North West Indiana
    6,097
    Dan, got a propane grill? That is basically what the turkey fryers are with a ring of fire around the pot. Your grill will probably put off more heat than what you have. I just got my mugs from Chuck, the steam bent handles and the mugs themselves are beyond belief/imagination/explanation. Whatever he says, follow it. I have 12 mugs here beside me that are testimony that he knows what it is he is talking about.
    Jon
    17,470
    Quote Originally Posted by Jonathan Shively View Post
    wait till you drink outa them they got magical powers in them you see strange thingsa fter drinkling out them good things of course
  1. Steam bending for boat building with a clever non steam box idea
    Last Post: 04-27-2015, 04:50 PM
  2. Steam Bending Revisited
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 05-25-2010, 05:12 AM
  3. Steam Bending ?
    By Don Baer in forum General Woodworking Q&A
    Last Post: 08-04-2009, 04:56 PM
  4. Steam bending or laminating stripes, when, how and why?
    Last Post: 08-24-2007, 02:14 PM
  5. Two Toboggans (illustrating steam bending techniques)
    Last Post: 01-10-2007, 12:26 PM
