Results 1 to 10 of 11
Thread: how flat is flat enough?
    Sep 2007
    Central (upstate) NY
    1,457
    I'm working on flattening one face of a 6' board by hand before feeding it to the thickness planer. Ultimately to be used as a table top glue up.
    I'm using a 48" (4') level as a straight edge. There is light showing in the middle of the level. Using my calipers, zeroing for the height of the level, I get 0.05" as the greatest deviation from flat.
    Would you guys keep moving iron or decide that the wood might well move more than this through the planer and call it flat enough to proceed?
    By the way, just in case there is someone in this forum that doesn't know, flattening a face by hand is hard, sweaty work!
    Carlyle IL
    350
    why don't you just take a piece of plywood, place your board on the plywood, shim the voids, run it through the planer to get one side flat.
    then flip the board over runt that side through and get your desired thickness
    Sep 2007
    1,457
    Because I tried that before and one of my pieces ended up too bowed for use. Not sure if it was technique or movement after milling.
    Also, I've been on a bit of a hand tool buying spree lately and want to play with the new toys.
    30,002
    Personally, if I was within 0.05" of flat in 6' of length, I'd call it good and head to the planer. But that's just me...others with more flatwork experience might disagree.
    5,317
    0.05 is 1/20th of an inch. I'd try for about half that before heading to the planer. A well tuned #7 or #8 will take care of the problem with just a few minutes more work. Don't use a shorter plane because it'll just ride the existing contour.
    15,806
    Depends what that board is being used for, a stair tread, I'd not worry so much, but some things might need a bit tighter tolerances
    Sep 2007
    1,457
    I've been going across the grain with my #6. Thank you for the suggestion to move to the #8.
    17,470
    keep us in the loop mark!!!
    Apr 2009
    Remlap,Al
    87
    no matter how you flatted the board when you flip it and run it in the planner it will move again, you are removing the stress on the back side. if you want a board that is true and that will stay that way. you need to sneek up on it. i flatten with my 8" jointer then peal a little off the back with the planner and set it aside for a few days and go back to the jointer again. i will do this a few times till i get to the size i want. i then will do my glue ups. ive never had a door or table go south on me yet.
    4,551
    Guys if its off by 1/20" just go set down and wait about an hour or two then it will ether be right on or 1/10 of an inch off.
    Hate to be the one that tells y'all this but wood moves and cannot hold that tight of tolerance.
    Put'er thu the planer and get on with the project. :
    (DISCLAIMER)
    This is my opinion and worth exactly what you paid for it.
    A Turn N Time
    Frog Pond Guitars
  1. Well, it started out flat!
    By Russ Wood in forum Flatwork Project Showcase
    Last Post: 01-19-2012, 12:24 AM
  2. Round and flat.....
    By michael james in forum Lathe Project Showcase
    Last Post: 07-04-2011, 08:35 PM
  3. OK. How flat does it have to be?
    Last Post: 09-06-2010, 02:58 PM
  4. ...and now for something completely flat...
    Last Post: 01-26-2008, 02:25 AM
  5. This is real flat
    By Pete Simmons in forum Flatwork Project Showcase
    Last Post: 08-12-2007, 05:30 PM
