Results 1 to 10 of 16
Thread: solid oak pedestal walls or plywood?
    new york city burbs
    10,184
    help please. someone with experience or knowledge.
    This is a rough, very rough not to size sketch, from top view, birds eye view of the pedestal style base IM making for my 2 inch thick oak top.
    There will be 4 3x3x28 posts, one on each end, 2 in middle with a shorter one sandwiched in so I can put a very hefty stretcher in the center to support the weight of the top.
    The 3x3 posts are 4 boards glued up.
    There will be 1.25-1.5 inch thick mahogany ends covering up the glueups on each end of each pedestal(2)
    In the drawing, again, not to size at all, I indicated where the oak side laminated to the posts will be. Im beginning to think Im going to have movement problems with the mahogany end caps glued up on the solid oak with no room for the oak to expand or contract.
    Will this present a huge problem? Should I just use white oak ply and make my life simple?
    Im not changing the design, I spent alot of time cutting , milling and glueing up all these posts. I have to live with my design, but Im not sure about wood expansion and I dont want to have to create some type of breadboard end for the mahogany caps, too much work, much too heavy and clumsy a piece to work with for any precise joints like that.
    Again, this sketch is rough and not to size, I hope someone understands what Im asking from my sketch.(the end caps of mahogany are labelled MAH in sketch)
    there will be more open space than the sketch indicates, since the posts at each end are only 3 inches wide.
    I didnt want to call anyone and disturb them today, so Id appreciate any help I can get here.
    And please understand, I wont change the design, I sink or swim by how I design things, so I have to deal with what I did. Id prefer to use solid white oak sides for the pedestal base, but will compromise with plywood if it makes more sense.
    If I'm reading this correctly this is going to be a solid looking leg/pedestal with mahogany caps? I would use ply for the sides and put a quirk at the point the mahogany and plywood meet to take care of any unevenness due to expansion and contraction of the wood. You could do a 1/16" x 1/16" or use a v-groove bit.
    new york city burbs
    10,184
    IM not understanding what youre saying, but Im not that concerned about the mahogany, Im more concerned if I used solid oak walls and then glueing the mahogany onto the ends. what is a quirk?
    It's another name for a small reveal. If all the grain is going to be running the same direction then go for it.
    5,317
    Allen,
    With the oak portion being only 4˝" wide, it shouldn't move much - if at all - seasonally. I'd just go ahead with your plan and do the glue-up.
    Oct 2009
    Lindale, TX
    84
    I agree with Jim. With the size you're dealing with, you're not going to have enough movement to worry about. I've done much bigger solid wood pedestals with solid wood caps and had no issues.
    new york city burbs
    10,184
    thanx, Ill continue the wood milling tomorrow, all the posts are glued up and will be sized correctly tomorrow. Then Ill start the walls of the pedestal, and then on to the stretcher and top.
    gonna see if that festool saw glides along with that 3 inch oak like the guy on the video. Got me alot of 3 inch oak to cut.
    Allen, after reading that last post of yours, I think you owe me a new computer, I was laughing so hard I squirted Iced tea out my nose onto my keyboard.
    new york city burbs
    10,184
    I thought best to delete it, cause even though it wasnt a religion thing, I didnt want to offend anyone. I mean, a jew making crosses?(the person who requested the crosses requested the bottom be extended more)
    new york city burbs
    10,184
    WARNING:POST CONTAINS GRAPHIC PICS:do not view if heart or stomach problems
    sometimes ya just gotta laugh at it all.
    I tell ya, Im not having a good time with this white oak this time.
    shoulda just used plywood.eh.
    I fought with the jointer since 2 pm, Im really not familiar with the mechanics of it all, even though it seems quite simple to me, and I ruined alot of pieces, seems I planed them on an angle.
    I slowly and carefully adjusted everything, and seems I finally got back on track. I had to wax on wax off all the beds, this white oak is tough stuff.
    I got spoiled working with mahogany so long.
    I was looking over all the support pieces of the base I laminated together, making sure Im happy with it all before I continue, and figured, yeah, it will hold a 200 lb table.
    I was taking pics of the base pieces, and told my daughter, Im going to climb and stand on it to make sure it will hold any weight.(Im a big boy)
    So my wife walked over and picked up the camera, thought I was about to kill myself, guess she wanted to show the insurance company proof how I died.
    I tried to give her my muscle man pose,(it turned out looking like Im constipated) or maybe the swan stance from Karate kid, since I had the head band on, but with my crew cut, and my double chin, its not a flattering picture.
    Not at all. . Ya gotta have some fun or whats the sense of any of it.Sometimes woodworkers are just so serious.
    the center stretcher will be longer, I just used the other laminated parts for the base to stand on.The entire base will be wrapped in 3/4 white oak and mahogany, none of these supports will be seen.the good thing is alot of the base parts were old white oak cabinets with dados and cuts in them, I was able to plane down and use all the cabinet parts instead of just tossing them. I never paid for any of those parts, the wood guy threw it in said if I ever wanted to trim it up or cut it down for smaller parts
    Attached Thumbnails Attached Thumbnails bed 313 (Medium).jpg   bed 314 (Medium).jpg   bed 315 (Medium).jpg   bed 316 (Medium).jpg
  1. SU8: Solid Tools
    Last Post: 09-11-2010, 05:41 PM
  2. Solid legs or glue up?
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 07-22-2010, 05:27 PM
  3. Solid bottom drawer question
    Last Post: 10-07-2009, 01:42 PM
  4. Solid core door project
    By Royall Clark in forum Flatwork Project Showcase
    Last Post: 01-26-2009, 04:44 PM
  5. Solid Surface Class
    By Mike Henderson in forum Off Topic Discussion
    Last Post: 09-27-2007, 06:06 PM
