Results 1 to 7 of 7
Thread: Difficulties in First Attempt at Casting ........
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Thumbs down Difficulties in First Attempt at Casting ........
    Sierra Canadian Shredded Currency pen blanks using Resin Saver mold rather than pouring a slab and having to use a pressure pot.
    1. Found that the spray adhesive used on the brass tube reacted with the PR resulting in some of the shredded pieces of money coming loose and floating to the surface.
    2. The resulting reaction of the PR on the adhesive also caused the release of a lot of air bubbles which I was able to remove with no problems.
    3. With some of the pieces of shredded money floating to the surface resulted in some voids and tear-out while turning.
    4. The voids and tear-out were easily repaired with Med CA.
    I am going to try some different methods of adhering the shredded money to the tubes to see if I can find a product that will not react with the PR.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Aug 2008
    Reno, Nv
    3,632
    Where can one purchase the mold Les?
    Apr 2009
    1,083
    Quote Originally Posted by Jim Burr View Post
    Jim,
    I got mine here:
    http://www.penturners.org/forum/showthread.php?t=57377
    Les
    Thanks for the post, Les. Do you suppose a water-based glue like Elmer's or Titebond might work better for holding the paper to the tube? I think it'd resist the plastic resin.
    Apr 2009
    1,083
    I tried the water based glues and I think that could be the problem.
    Les
    13,361
    What about a spray glue and 'rolling' the tubes in the paper?
    Apr 2009
    1,083
    Tried some spray adhesives with no success as of yet.
    Les
  1. trying my hand at casting
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 06-03-2013, 11:16 AM
  2. My First Feather Casting
    Last Post: 07-03-2010, 02:28 AM
  3. Casting Difficulties Resolved
    Last Post: 06-11-2010, 05:30 PM
  4. First Attempt At Casting .............
    Last Post: 06-07-2010, 03:55 PM
  5. My First PR Casting
    Last Post: 05-18-2010, 03:11 PM
