Results 1 to 6 of 6
Thread: Casting Difficulties Resolved
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Thumbs up Casting Difficulties Resolved
    Initially found that Polyester Resin reacts with the Elmer's Spray Adhesive causing the shredded money to come loose from the brass tube and float to the surface.
    Found that if I saturate the shredded money with Thin CA after it has been glued to the brass tube with Elmer's Spray Adhesive that there was no reaction with the Polyester Resin.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    30,014
    Looks flawless from here. Thanks for the tip, Les.
    That is very neat!
    So I guess you are buying the shredded money from somewhere, what does it cost?
    13,360
    Great tip Les!
    Apr 2009
    1,083
    That is very neat!
    You can get a 20 - 25 lbs. box from the Bank of Canada in Montreal for a total cost of $75 including GST/PST and shipping.
    Les
    17,471
    hey that is pretty good turn around you make the stuff ,then you take it back and shred it and then yu sell it to those that gave it back in the first place
  1. pocket door problems - RESOLVED!
    By Carol Reed in forum Carpentry and Construction
    Last Post: 11-24-2014, 03:08 PM
  2. Makita 2012 NB Planer Issue Resolved
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 02-15-2011, 02:34 AM
  3. Difficulties in First Attempt at Casting ........
    Last Post: 06-08-2010, 04:10 PM
