Results 1 to 8 of 8
Thread: Bandsaw speed
    Bandsaw speed
    I have a two speed bandsaw. According to the manual 1450 ft/min is recommended for hardwoods and the 3000 ft/min is for all other timbers (softwood I presume). I read an article recently that said to use high speed for all woods and low speed for metal. Any advice?
    Thank you, DKT
    I run mine on high speed for all wood, I don't cut metal on mine but if I did it would be at low speed.
    May 2009
    Poway, CA, near San Diego
    174
    Hi folks,
    1450 is still way too fast for any metal except aluminum.
    I have a metal/wood bandsaw that has a gearbox to reduce the speed to about 60 fpm (yes, 60) That's the speed you need for steel.
    Bob
    High speed for all woods here too.
    Tellico Plains, Tennessee
    4,351
    My bandsaw only has one speed so I guess I use high speed for all woods... don't do metal on it... only metal I ever cut is brass tubes occasionally and I use an older Ryobi for that... so as not to ruin my wood blade.
    Chuck
    Tellico Plains, TN
    Jun 2007
    4,944
    Hi,
    I do the same as Don. I use only high speed. I do not cut metal. I have not had any problems.
    I mainly use 4 tpi half inch blades.
    Enjoy,
    Jim
    VOTING MEMBER
    Mar 2009
    Lincoln AR
    142
    Ya high speed works, if you have cherry and a dull blade you might slow it don't to keep from burning it, but you don't run dull blades do ya? You might consider a cheap 42 inch horizontal saw for your metal needs. Morse make a variable tooth blade that well cut all metals (aluminum included). it has 14 teeth to 10 teeth, all on the same blade that's all I run on my metal saw .
    11,830
    Mine is two speed also but I have never used the slow.
    For big chunks of hardwood I just go easy on the feed.
  1. Two-speed drills
    By Roger Tulk in forum General Woodworking Q&A
    Last Post: 07-12-2012, 08:36 PM
  2. Need for speed
    Last Post: 03-26-2011, 09:31 PM
  3. slowing down the speed???
    Last Post: 06-15-2010, 08:13 PM
  4. DSL Speed
    By Bartee Lamar in forum Off Topic Discussion
    Last Post: 10-19-2009, 01:08 AM
  5. Site Speed
    By Jim Young in forum Off Topic Discussion
    Last Post: 11-05-2006, 12:01 AM
