Results 1 to 8 of 8
Thread: Another Dyed Sycamore Hollow Form
    30,009
    I finished this one up a few months ago, but kept forgetting to get pics of it when I had the photo tent set up. It's sycamore, 9 3/4" wide and 8" tall, dyed with sprayed TransTint in about three colors. The finish is sprayed waterbased lacquer (USL) and I left it unbuffed...kinda liked the satin finish.
    I started this blank out thinking I'd core some bowls, so I had it mounted on a faceplate to start. Changed my mind after getting it round, but had to use a large opening to turn out the faceplate screw holes. The biggest disadvantage to doing hollow forms with an opening this big is that you can reach your hand inside, so you gotta sand it, too. I should've gone with a smaller foot, too.
Name:	HF057 - 01  800.jpg
ID:	46283 Click image for larger version.
Name:	HF057 - 02  800.jpg
ID:	46284 Click image for larger version.
Name:	HF057 - 03  800.jpg
    Comments, opinions, critiques and suggestions are all welcome.
    Jul 2007
    DSM, IA
    5,719
    Vaughn I agree about the smaller foot. I really like the rim on it! The dye looks great too. Is the interior black or is that just a photo illusion?
    My Website
    Pickles Gap, Arkansas
    271
    Very nice, Vaughn. I like the rim a lot and the color as well.
    If you have a pulse you have a purpose...
    13,360
    I like the color on it. Kind of 'sunburst' in appearance...
    Los Angeles, CA
    2,668
    I like the rim too. The foot could have been just a tad bit smaller but it is still a pretty piece as it is.
    Oct 2008
    Cumming, GA
    49
    Aint nothing wrong with that at all Vaughn, beautiful piece
    www.misfiregamecalls.com
    R.I.P Echo 7 #1700
    30,009
    Thanks guys. It's funny, because a number of comments here and elsewhere have mentioned liking the rim, and that was one part I wasn't sold on myself.
    ...Is the interior black or is that just a photo illusion?
    It's natural sycamore color. I just used clear USL for an interior finish, so it's not even darkened as if I had used an oil finish. It sure does look black in the photos, though. It's a bit tricky spraying dye without getting any inside the vessel. To mask the hole from the inside of the piece, I stuffed it tightly with wadded newspaper, then slipped a piece of closed-cell foam under the rim to seal the hole.
    Aug 2008
    Reno, Nv
    3,632
    All looks fine from this angle. The bigger hole means it's easier to hollow ...right
  1. Dyed Maple Hollow Form
    Last Post: 09-21-2009, 04:54 PM
  2. Little Dyed Sycamore Bowl
    Last Post: 03-04-2009, 08:43 PM
  3. Dyed Sycamore Bowl
    Last Post: 12-24-2008, 05:54 PM
  4. Dyed Sycamore Natural Edge Bowl
    Last Post: 06-01-2008, 06:49 AM
  5. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
Tags for this Thread
