Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 92
Thread: Concrete Counter Top
    13,360
    Decided a house isn't a house without a utility sink for washing out things like paintbrushes, rollers and such. Just doesn't feel right doing it in the kitchen sink.
    Decided to remodel 'my' little bathroom. Kind of an odd room between the den and the garage. They even put a shower in there. It had a basic lavatory, but we thought it would make more sense to put a cabinet in there with a utility sink. And the brilliant idea is that I was going to make a concrete counter top for it.
    It's going into a very small little nook in "my" bathroom. I made a cabinet for it with a poplar face frame and doors made out of poplar with birch ply panels. It's not great, but it's not that ugly. I actually think it will work. Here's a pic of it with the utility sink mounted and a temporary melamine counter top.
    Got the mold made and the rebar fitted.
    Still have to do some cleanup on the mold, and will probably do the pour in a day or so. I'll keep you posted...
    10,604
    17,472
    dont they put some silicon in the corners so you dont have sharp edges? or some other type of filler..a router wont round over the crete very well and will end up being rounded over itself if you try it
    North West Indiana
    6,098
    Brent, that unsupported "wing" on your current counter, I assume you are recreating that with the angled area on your pattern. I am not expert, but would think it can't "hang" like the current counter top even though there is wire in it. Some type of support brace front and rear from the counter to the wall is going to be needed.
    Are you going to leave the wire in the pattern and pour or are you going to pour then vibrate the wire in. Hear it is a bummer when you vibrate the wire to the pattern's bottom so it shows up in the top of the counter. I have considered building one of these from time to time and figured I would use string and fender washers so I knew when the wire reached the center.
    I don't know about the exertions of the concrete, but a diagonal brace inside the sink cutout would insure no unwanted angles.
    So, adding color? Hope you take pictures and document this as you go. Would really find it interesting. Good luck and have fun. If the first one doesn't work out, going to put it out for a flower bed?
    Jon
    13,360
    Need to take some more pictures. I used some black caulk, but kind of made of mess of it. I'm cleaning it up and will be redoing the front edge...
    Quote Originally Posted by Jonathan Shively View Post
    I've got cleats on the wall on the back and side. I'll also be putting a support strip across the front when I go to install it.
    My plan is to mix up a fairly dry mix and to hand pack it about half way, put in the rebar, then pack it the rest of the way. Good idea about doing something to keep it from vibrating to the bottom. Maybe I'll just use some wire and screws around the edges.
    For color I'm going with some black iron oxide. We'll see how dark it gets.
    The whole thing is kind of an experiment, which is why I've got the temporary counter top in place.
    If it doesn't work out, I've already got a huge pile of busted concrete the previous owners left for us. I reckon a counter top won't add much to the pile...
    Bellingham
    2,449
    Hey, get to pouring. I want to see how it turns out!
    11,831
    I just don't get the attraction to granite and concrete counter tops. Both are very heavy, prone to staining and cracking and expensive. Formica or Corian make fine tops, IMHO, with less fuss and bother.
    What am I missing?
    13,360
    Durability, appearance, etc..
    I like the way granite, stilestone, concrete counter tops look.
    I've seen formica counter tops that looked pretty worn our after not too long a time due to abuse.
    Different strokes for different folks!
    What am I missing?
    Frank,
    we've had these granite counter tops for 3 years and love em. Had tile in the first house and 3rd house and formica in the second house. The groute gets satined in the tile ones and the formica will scratch and discolor. The granite well what can I say it's granite so it'll outlast me. This is how they look today and this picture wasa taken Feb 2007.
  1. counter top kiln
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 04-05-2013, 12:23 AM
  2. Counter top Finish
    By Gary Rutledge in forum Finishing School
    Last Post: 01-13-2012, 05:10 AM
  3. Best way to cut a counter top
    By Howard Van Huis in forum General Woodworking Q&A
    Last Post: 12-03-2010, 06:40 PM
  4. Counter Top Alignment
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 08-12-2010, 04:57 PM
  5. Concrete Counter Top Tips?
    Last Post: 05-24-2010, 02:20 PM
Tags for this Thread
