Results 1 to 4 of 4
Thread: Mistakes and Success
    Palm Springs, Ca
    1,167
    Had the day free and worked in the garage on a few projects that have been sitting. Then i got called away late in the day and forgot to take the turnings inside and left for several hours. When I returned I was in for a suprise.....Southern Calif Heat is intense........
    Picture #1 ----Cracked on both sides right down the middle. I held it together and dripped CA glue into it. Then steel wooled it down and put a coat of semi gloss laquer on it...............it will be a give away thing when done...............dang
    Picture #2 ------Same thing with this small Walnut vessel but I opened up the crack and put some black dye around the edges, sanded and put a couple coats of laquer on it.......letting it dry now......another give away when im done......double dang
    Picture #3 ------Again, this was left out in the summer heated garage and waalllla .......crack.......this one not repaired as well as i had hoped.....quick coating of wax and will either go in the junk pile or given away........................just not my day so far.......dang dang dang
    Picture #4 & #5 ---- Then I managed to put the last coat on my large vessel that had been sitting.....Now letting it dry for a week or more for the finish to cure well.......put a finial on it for one of the pics but not sure it looks right so ill probably leave it off or make another one........but this put a good end to an otherwise bad turning day.......
    Attached Thumbnails Attached Thumbnails Small-1.jpg   small-3.jpg   Small-4.jpg   Small-7.jpg   Small-2.jpg
    Tellico Plains, Tennessee
    4,351
    Dan,
    I rarely take my work pieces out of the shop until they're finished... but then you do live in the desert, which is much drier than here in TN.... last week humidity here was almost as high as the temperature and it was in the high 80's and low 90's all week.
    Chuck
    Tellico Plains, TN
    30,008
    Dang, that sucks about the cracking. Not much you can do once they crack. Any fix looks just like...a fix.
    The NE hollow form looks pretty cool, but I think it looks better without the finial.
    Palm Springs, Ca
    1,167
    Yeah im going to leave the finial off of it ......the finial is one of a small basket of them I turn and save for vessels and other projects.....this form just looks better without any finial ....or possibly a short stubby one.....
    The cracked ones ill just give away or add them to the burn pile.................ahhhh well
    Yep its not Tenn wheather......temps here push over the 110's and dry.....so the garage is like a oven and with fans going is like a oven with blowers.....I have had good luck with the turnings when bringing them inside.......cooler ya know...............
  1. making the best of mistakes
    Last Post: 10-12-2015, 12:43 AM
  2. 2 Mistakes and 2 Saves I hope
    Last Post: 07-19-2010, 12:39 PM
  3. Dogs, scoops and mistakes
    By Travis Johnson in forum Jigs and Fixtures
    Last Post: 02-29-2008, 06:07 PM
  4. mistakes
    By Chris McDowell in forum General Woodworking Q&A
    Last Post: 10-09-2007, 02:02 PM
  5. Learning from the mistakes of the past.
    Last Post: 11-22-2006, 04:32 AM
