Results 1 to 10 of 17
Thread: Working Corian?
    Dec 2009
    Madison, WI
    206
    Working Corian?
    While trolling eBay for bargians, I found someone selling Corian pen blanks. Can these be turned on a lathe just like wood? Are they machinable? I might be able to beg access to a CNC machine, and laminating a few layers of scrap Corian together seems like an economical and extremely strong material.
    13,364
    Depends on what you want to use them for, but they are very machineable with standard woodworking tools...
    Dec 2009
    Madison, WI
    206
    Do you think I could work it with a standard (~1.5HP) plunge router and cheap carbide bits?
    Quote Originally Posted by Joseph Shaul View Post
    That should work. You probably should take fairly light cuts, but if a HSS chisel works on Corian spinning at 1000 rpm on a lathe, a carbide bit at 10,000 rpm should be fine.
    15,809
    I turned one a while ago, it was so nice, Emiko snatched it right out of my hand when I showed her, and it is now "Her" pen
    Tellico Plains, Tennessee
    4,353
    This is interesting question... I've turned one corian pen... no problems with the turning... I think I did it before I got my little lathe, so it was done on a Ridgid spindle lathe.. probably about a 14 x 46 bed... the corian turned fine.. smelled a little like vinegar when I turned it, but in the end, I didn't like the pen.. I think it's kinda bland - like blah - so haven't tried another... even threw away the other pieces of corian I had when I moved.
    I still have the pen and put it out with my other slimlines when I do shows... so far no takers... it's been in the inventory about 6 or 7 years now... think I'll take it out to the show for a shop pen... I need a new out there anyway.
    Chuck
    Tellico Plains, TN
    13,364
    If you are working with small and/or glued up pieces, just make sure the workpiece is held securely. And take small bites. Wouldn't want it catch and blow up!
    11,833
    It is turnable but not easily. The old adage 'sharp tools and light touch' applies to Corian.
    It can be CA glued with good quality CA. Dunno why but not all CAs will work on it.
    Corian does soften with heat. Note the "light touch" advisory.
    I had a large box full of slabs and blanks and gave it away.
    Long Hill Township, NJ
    467
    Interesting thought - I have a sink cutout from 3/4" white corian . . . I was going to use it for a router table but never got around to it.
    A white corian european pen with platinum might be cool looking. . . Must cut a blank off and try it . . . It might look pretty blah too . . . I'll let you know . . .
    Jim
    Dec 2008
    falcon heights, minnesota
    5,610
    what about adding a celtic knot to the corian? with that white background, it would really stand out.
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Corian is Nasty
    Last Post: 01-09-2014, 11:36 PM
  2. Left over corian
    Last Post: 07-10-2011, 05:37 PM
  3. Milling Corian countertops
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 07-15-2010, 04:15 PM
  4. turning corian
    By Sandra Meyer in forum General Woodturning Q&A
    Last Post: 11-30-2009, 11:28 PM
  5. Getting small pieces of Corian
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 07-08-2007, 04:30 PM
