Results 1 to 3 of 3
Thread: Iron Wood
    Palm Springs, Ca
    1,166
    Iron Wood
    Another day off of work today.....but back at it tomm.....so I picked up some of the iron wood I was talking about on an earlier post and decided to try a small section out to see how it turns.
    Pictures 1-2 is some of the green ironwood I got and sealed the ends up and stacked up on a work bench
    Pictures 3,4,5 are the small vessel I turned to completion in one session - 2 coats of DO and now sitting out in the open inside the house. When I had the form the way I wanted it, I was able to shear scrape very lightly and create a very smooth finish - started sanding at 180 on this and ended at 320. Wet this wood cuts very nicely........
    Pictures 6-9 are the mesquite vessel with its finish coat of semi gloss laquer on......now sitting inside for the next week....then will probably steel wool down the finish and buff with Renaissance.......or something along those lines.....Picture 9 is just before I brought it inside - last coat drying
    Attached Thumbnails Attached Thumbnails Saturday-21.jpg   Saturday-2.jpg   Saturday-3.jpg   Saturday-4.jpg   Saturday-5.jpg
    Jul 2007
    Des Moines, IA
    854
    I like them both. I especially like the first one.
    Beauties!
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
  1. Old Iron
    By Bart Leetch in forum Old Iron
    Last Post: 05-18-2011, 03:52 AM
  2. Iron Wood v. Oak Question
    Last Post: 06-09-2010, 02:24 PM
  3. Old Iron or "Wood" Now with Pictures..
    By Garry Foster in forum Old Iron
    Last Post: 02-13-2009, 12:13 AM
  4. Can you say old iron???
    Last Post: 01-27-2007, 04:41 PM
  5. My first ole iron
    By Marty Walsh in forum Old Iron
    Last Post: 01-21-2007, 07:19 AM
