Results 1 to 8 of 8
Thread: I want to take it apart in a year or four
    Jun 2007
    4,944
    Hi,
    I wish to place a piece of one-eighth inch thick tempered masonite panel over the top of my bench. I would like to be able to replace it when it gets beat-up. In the past I have pinned the outside perimeter about every 6 inches and did not glue. This time I would like to glue it and omit pins so there is no metal in the top.
    Somewhere, in the past, I read that diluting Original Titebond a certain amount with water would leave it strong enough for a bench "cover" yet make it easy to remove in a few years. I don't know what dilution was recommended and I'm not even certain it was the Titebond. In other words, "I don't know squat."
    Any recommendations for attaching the temperboard in a way I can remove it later without destroying my bench top?
    I did try Google search and I did try <titebond.com> without success.
    Thanks and Enjoy.
    Jim
    I have been taking photos of the bench modification and the installation of the 12 inch Rockler vise. I will show them when the job is done.
    VOTING MEMBER
    This is one instance where I would recomend Hide glue.
    Hide glue will hold and then a simple electric iron can release it, at a later date. Also diluted White glue, PVA glue, will steam loose.
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I have used carpet tape and it works great for me. Go around the edges and a few strips down the middle.
    11,833
    I would go for rubber cement. It will hold and when you are ready to remove just pull up, it will peel off. However, unless you are some kind of bench killer monster, methinks the top will out last you.
    Apr 2009
    Outside the beltway
    5,259
    We use lacquered massonite boards also. But the 1st one is tacked down with a pin nailer then glued a layer down. I just applied a new layer to it by glueing it down.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Southeast Pa
    2,019
    I have used nylon bolts for things like this.
    No damage if you cut into them...Well except for the bolt!
    Garry
    I'll second the rubber cement suggestion. Apply to both surfaces, let it get dry enough that you can touch the glue without having it stick to your fingers, then put the Masonite in place. (Be sure to have it aligned when you set it down, because it won't want to shift after the two surfaces make contact.) It'll stay as long as you want, but still be pretty easy to peel apart in a few years if necessary.
  1. Value of 6+ year old TS???
    By Al Launier in forum Classified Ads
    Last Post: 03-19-2013, 01:45 PM
  2. Once A Year!
    Last Post: 12-28-2012, 01:26 AM
  3. I may get to start on this later this year.....
    By Jim O'Dell in forum Designs, Plans and Sketches
    Last Post: 03-10-2012, 01:02 AM
  4. Happy New Year Everyone!
    Last Post: 12-31-2009, 11:27 PM
  5. First of the year
    Last Post: 01-02-2008, 12:42 AM
