Results 1 to 10 of 10
Thread: flat panel cabinet door w/ glass question
    Jun 2010
    3,220
    If you were making flat panel cabinet doors, and you wanted some of them to have glass, would you buy the glass and do it yourself, or would you farm it out to a glass person?
    AKA The Rookie
    NH
    4,005
    Buy the glass and install my self.
    Don't forget glass is cheap get an extra
    Stupid hurts.
    5,321
    I'd do it (have done it) myself.
    Have the glass cut about 1/8" smaller all around than the opening in the door. Buy "double-strength" glass. It only costs a little bit more than 'regular' stuff.
    You can install the glass using either glazers points or a small quarter-round molding.
    17,472
    yup on both replys, and second the fact of gettin a spare for the door size.. when yu least expect it it will break.
    I take my frames, either picture frames or Cabinet doors to my local Hardware store. She cuts the panes and tapes them in the frames and I pick them up later. Then I affix them in place. (She is located 1/2 mile down the road, Was a Mom & Pop store but now a Mom & Daughters store)
    London, Ontario
    3,383
    I've only done a glass door once. It was 10+ years ago when I built a stereo stand. I knew that the door would be opened and closed over and over and over again, and sometimes roughly. Therefore I thought it worthwhile to go to a glass place and order tempered glass. Yes, it cost a lot more, but the piece of mind was worth it to me.
    My glass just sits in a rabbet and is held in place with clips.
    +1 on getting the glass from a local shop and putting it in yourself. You will be surprised how easy it is. I use these to hold the glass in place; 2 on each side.
    Jun 2010
    3,220
    Thanks guys--didn't realize it was that simple. yeah I know glass is cheap, and my LOML was a glass contractor for 30 years, so I have......connections....
    AKA The Rookie
    Austin, Texas
    1,448
    I take the opposite approach. I make and finish the doors, then taken them to a glass shop. The glass is glued in with a clear silicone glue (like bathtub or aquarium sealer) so is secure and cushioned to not rattle. The cost of the "installation" at the shop I use is only $1.50 (although another shop charges $10)
    Charlie Plesums, Austin Texas
    Oct 2009
    Dennison, MN
    512
    With out reading other replies.....
    I have the glass cut to size by a glass place, then install it after finishing is done. I just use silicone to hold the glass in, its cheap, doesn't rattle, and can be easily cut out if replacement is neccessary. I just place the glass in the opening and do a small bead around the edges.
    Rattling is the big one for me, drives me nuts.
    "Do, or do not. There is no try."
    -Yoda
  1. Stile and rail panel door question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 03-07-2013, 03:45 PM
  2. Cabinet Door Hinge Question
    Last Post: 04-20-2011, 12:12 PM
  3. Frame and Panel Cabinet Doors Question
    Last Post: 06-27-2010, 05:25 PM
  4. cabinet inset door question
    Last Post: 06-23-2010, 04:28 PM
  5. Glass Real Flat Glass
    Last Post: 11-13-2009, 04:40 AM
