Results 1 to 10 of 16
Thread: Drilling a lamp
    Drilling a lamp
    I want to try and make a lamp but don't have any idea where to get a drill bit that would be long enough to drill out the center. Is there a special trick or drill bit that I need to use. I would think a regular drill bit would wander all over the place. I want to make the lamp at least 12 inchs tall and that is just the wood. Any one made one or have any idea where to get what I need.
    Dennis
    30,017
    Dennis, I know some folks use a 'gun drill' for that type of long hole. I have no personal experience to offer on using one or where to buy it, but I figured knowing the name might give you a starting point.
    10,604
    I have several "bell hanger" bits. They are used by electricians. They work well if you keep the drilling pressure light and clear the hole frequently.
    I think you will drill from both ends, and yes there is a special bit for doing this, as it is long and has to easily clear the chips.
    I think you also need a special hollow live center for this too.
    I remember an article in the AAW magazine about it last year....
    Time to fire up google
    North West Indiana
    6,099
    Our local lumber yard had a bit when I needed one for students that were turning lamps. It needed cleaned frequently. We turned, sanded and then finished the lamp on the lathe, then we would clamp it in the vise and stand over it on a chair and using a hand held drill, drill through. We took the measurement of the rod that goes through and then got the bit.
    Jon
    12,258
    Dennis, when i built my shop i needed a long bit when doing the electric wiring. I found them in two forms at Home Depot.
    1) An extension for a spade bit. But in this case the diameter of your hole would be large as the joint is pretty thick.
    2)A long drill used by electricians to drill between the floors through the wall plates and the joists. Take a look at the tool section at HD but also in the electrical section i think its marketed by Greenlee if my memory serves me correct.
    But you will need to think about a drill press that is a floor model as opposed to a bench top. I doubt a 12 inch lamp plus 12 inch drill would make it under my bench top drill press. Alternative if you gonna turn the lamp you might manage it in a chuck mounted in your tailstock.
    Best of luck dont forget to show us your project as you progress.
    11,833
    I had a very long drill bit made years ago to drill ramrod holes for muzzle loading rifles. It is a standard 3/8" twist bit. And, yes, it does wander. I made a lamp recently and drilled before turning, thus eliminating problems from the wander. A good machinist/welder can make up a bit like this for you at not much cost. I have several extra long bits and augers and pull one or more out for use about once a year. Nice to have when that unusual need comes up. BTW, back out frequently to clear chips since there are only a couple inches of flutes at the front to do that job.
    S E Washington State
    3,777
    You could cut the blank in half, route a groove down the center of each half and glue it back together.
    Phoenix, AZ
    112
    I've made a couple of lamps with one of these,
    http://www.woodturnerscatalog.com/st...mp_auger?Args=
    from craft supplies. You also have to have a hollow tailstock or headstock and a hollow dead center for the tailstock or a hole through the headstock and whatever you are using to drive the wood. Mine was only 5/16 and considerably cheaper at the time.
    A gun drill is supposed to be better. Also, I have bought 12" bits from the local ace hardware if that is long enough.
    Aug 2008
    Reno, Nv
    3,632
    Home Depot, Lowe's and the like sell 12" and 18" Auger bits that should work for that. It is best to drill from each end so any deviation is minimal...kinda like doing a pepper mill.
  1. Lathe Drilling Jig ?
    Last Post: 02-19-2014, 05:58 PM
  2. Pen Drilling Jig
    By Raymond Sprouse in forum Jigs and Fixtures
    Last Post: 05-26-2011, 10:25 AM
  3. drilling steel
    Last Post: 05-30-2008, 01:26 PM
  4. Pen Drilling Ideas
    Last Post: 04-22-2008, 01:14 AM
  5. Lee Valley Drilling Kit
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 11-30-2007, 09:09 PM
