Results 1 to 10 of 15
Thread: L-O-N-G tool rest.....
    15,811
    OK, I'm getting at this spindle work stuff, I have to admit, it is a whole different animal than most of the stuff I've been doing on the spinny side.
    The spindles will be about 26", by 2 1/4", I've had a really hard time with whip, with not getting a smooth cut.
    Here is the LONG tool rest I made up......
    I've tired high speed, low speed, in between, and I've got SHARP tools, I mean SHARP!! but, still.............????
    I'll be working on it on Sunday, ALL DAY.....
    I made up a MDF power strop for the grinder......
    This works REALLY well on the lathe tools
    Took ten minutes to make, cut it rough, made it round on the lathe, then put it on the grinder, trued it up again, a bit, added some rouge honning compound, and I'm in business
    The leather one I have works great too, but if I'm on the lathe working....makes it kind of hard to use, this is DEAD easy!
    I'm going to have to make a steady for this spindle work, I guess......
    Any tips and or tricks for this stuff?
    I'm doing the "Supported" by hand cuts, and cuts as light as I can make them...... more practice I guess........
    The Heart of Dixie
    4,268
    Not much I can off Stu as I have turned very little long spindles but I have seen what your dealing with. Sandpaper is your friend!
    I did see a steady rest once that should work for spindles. It consisted of two wheels against the back of the spindle, mounted on a simple L shaped bracket. Your turning tool makes the 3 contact point. The wheels were skate wheels.
    With the welder you could whip one out in just a few minutes.
    Look the the first photo on this page, It's similar to what I saw.
    If you want some old iron for you new lathe This is cool.
    Hope that helps some, but I bet you were all ready on this.
    Jeff
    Custom built boats and Kits
    15,811
    Well, I think I can adapt my bowl steady to this spindle work, I just need to adjust it slightly.....
    11,899
    I tried to make some spindles for display shelves for my wife' bell collection. Before starting, I remembered that my father, who was a professional furniture maker, always bought his spindles and slender posts. When I started turning them, I found out why. Even with a steady rest, things get real 'whippy' and turning can be impossible. Type of wood makes a huge difference. I was trying hickory and that is a fairly flexy wood. Comes a point where the time and effort exceed the value of the end result. Sorry, no help here, I'm just ruminating.
    3,147
    Stu did you make the mount post on the right if you did how did you do it? If you did can you show pics.
    Also I like your pseudo plug in on the wall behind the lathe. What type of current do you get from it? I'll bet it real solid.
    Kutztown PA
    252
    Hi Stu
    Long spindle work can really be frustrating sometimes. How are you with your skew for planing those long straight sections? If you are comfortable, now you can practice with one hand, while you steady the tool and the wood with the other! Once you get the wood round, you can use the fingers of your non tool holding hand to gently steady the spindle. If you burn your fingers you are pushing too hard.
    First, get all the detail work done on the ends. Put the tool rest up high, so the skew is cutting almost on top of the spindle. Get it into position and hold it with your dominant hand. With your other hand, place your thumb on top of the skew and wrap your fingers around behind the spindle. Now you are ready to cut. Light cuts are essential here. The harder you push with the tool, the harder you are going to have to push with your fingers, and that starts to hurt real fast. With a little bit of practice, you will be able to keep your fingers on the smooth parts of the wood and avoid the part that is being cut at any given instant. This goes a long way to reducing chatter and those ropy looking cuts, and does it a lot faster and easier than working around a steady rest. Good luck with it!
    Bill
    Bill Grumbine
    www.wonderfulwood.com
    15,811
    Bart, OF COURSE I made it, what did you think, I BOUGHT it
    Bill, thanks, I'll give that a try, I have got the rope like cuts down pat
    Lyons Ohio
    25
    Hi Stu,
    One other thing that has not been mentioned is to make sure you do not have too much pressure on the piece being turned. Maybe the tailstock is a little tight. It can cause flexing on the turning. Try backing off the the ram a little.
    Also, nice looking long rest you have there. When I was doing Shaker chairs, I made one out of hard maple that was about forty inches long. It worked pretty well for those long back posts on the no. 7 rockers.
    Best wishes,
    Dave
    15,811
    Thanks David, I did try that too.
    Bill's advice to go almost on top seemed to work the best, and just more time at it, I was able to do an OK job, I think.......
    The ropy or wavy-ness was light enough that a few seconds with a #120 grit gouge and it as smooth sailing
    OK, some pics.............. Please understand, I'm just learning this, so the results are just beginners results, I'm sure the guys that have done a ton of these will see all kinds of errors!
    Well, there you go, got one done!
    Sanded to #320
    I did find that the leg looked too............. soft........
    the transitions are too......... smooth???
    I needed to add some accent points....
    I think this is better, not perfect, but better....?
    OK, on to trying to make one look similar to the first one....
    Certainly not a "Exact" copy, but "Similar", especially if they are at opposite ends of the table.....
    Yep, "Similar" might even be stretching is a bit, but I am learning.......
    What do you think?
    I think I need WAY more practice, so hear are the next victim, some pieces of "Hemlock! should be fun......
    15,811
    Oh yeah, here are two pics of the "Bango" I made to hold the other end of the long rest.........
    1/2" plate steel MIG welded to a thick piece of angle iron, then a 1" hole drilled in it, and another hole drilled in the edge of the plate and tapped for the locking bolt.
    Drill and tap the side hole before you weld the plate onto the angle iron.
  1. DIY Tool Rest
    Last Post: 05-07-2014, 09:01 PM
  2. S curved Tool Rest
    Last Post: 02-17-2010, 09:59 PM
  3. tool rest nut
    Last Post: 09-18-2008, 01:22 PM
  4. new tool rest
    Last Post: 01-23-2008, 02:29 AM
  5. A box tool rest..........
    Last Post: 11-14-2007, 04:49 PM
