Results 1 to 4 of 4
Thread: Ryobi dust collector
    5,172
    I have an old but goody Ryobi dry vacuum, the one with the cardboard drum. It works just fine but the foam sleeve, filter bag and rubber band have disappeared! The foam filter and rubber band are still available but the filter bag is not; and a pricey replacement at that!
    Anybody got a work around? The "cage" this all covers is a 6" diameter and about 6" height. Where might I get some foam filter and cloth filter material to fashion a new system?
    Dec 2008
    falcon heights, minnesota
    5,609
    i would think you could get the foam from an upholstery or fabric store, and cut it to size. just an idea...
    benedictione omnes bene
    www.burroviejowoodworking.com
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    The first vac that I had used foam and a paper bag that was held on with a rubber band. The vac I have now was just a paper filter that was letting too much fine dust thru. I cut the pant leg from some old blue jeans and put that over the paper filter. It seems to work good and has cut down on the fine dust coming back out the exhaust side.
    Aug 2010
    Charlotte,NC near airport
    12
    Carol, you might want to buy a foam air conditioner filter, from the hardware store and cut to size and wrap it around the air return unit inside then use a
    small bungee cord to secure it to the unit. As to a dust bag, check and see
    if one from a belt sander could fit, then again you might buy a dust bag from a Ryobi tablesaw user for a few bucks, the one's from the BT3000 & BT3100 might be what you need.
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. When does one really need a Dust Collector?
    Last Post: 06-17-2013, 06:30 PM
  3. Ryobi router dust collection-?
    By Dave Hanson in forum Jigs and Fixtures
    Last Post: 02-01-2010, 11:22 PM
  4. pics!! Ryobi AP1300 dust collection
    By Mark Kosmowski in forum New Tools
    Last Post: 10-06-2007, 04:29 AM
  5. My old ryobi table router has bit the dust
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 01-13-2007, 01:01 PM
