Results 1 to 10 of 14
Thread: A Few Quick and Dirties
    30,008
    I spent the last couple weeks before the Malibu show getting my stock of small, inexpensive pieces built up. Here are three magnetic paper clip bowls I finished up last week. After shaping the outside, I remove most of the inside with a Forstner bit, then enlarge it with hollowing tools. (The Ci1 carbide cutter is excellent for this, either freehand or in the Monster rig.) I leave the walls thick for weight, but get rid of the hole from the point of the drill bit and round the bottom corners of the inside. All of them have what I'd consider a gallery-quality buffed lacquer finish. After working on bigger things for the last while, these were a breeze to finish.
    Dye and limed ash, too glossy to get a good profile pic:
Name:	June 2010 Paper Clip Bowls - 01  800.jpg
ID:	46726 Click image for larger version.
Name:	June 2010 Paper Clip Bowls - 02  800.jpg
    Carob:
Name:	June 2010 Paper Clip Bowls - 03  800.jpg
ID:	46728 Click image for larger version.
Name:	June 2010 Paper Clip Bowls - 04  800.jpg
    Curly maple with black, red, and honey amber dye:
Name:	June 2010 Paper Clip Bowls - 05  800.jpg
ID:	46730 Click image for larger version.
Name:	June 2010 Paper Clip Bowls - 06  800.jpg
    These are comparable to making low-end pens in terms of time and cost, but a bit more flexible in regards to size and form.
    Questions, comments and suggestions are welcome...
    3,132
    Vaughn great work as always. I really like the dyed ash. To me the shorter one seems like it wouldn't get knocked around as much when getting the paper clips off it.If that makes cents.(to early in the am to think)
    Steve
    Palm Springs, Ca
    1,167
    Good job on all them and im sure they will sell well.................
    Question - can you explain in more detail how you did your finishes ?
    I always like to hear about how others are applying their finishes..............thanks Dan
    30,008
    ...Question - can you explain in more detail how you did your finishes ?...
    Pretty simple and basic. The dyed ones got four or five coats of spraycan lacquer, hand-rubbed between every couple coats with white synthetic steel wool to remove the dust nibs, then buffed with Don Pencil's PL compound, followed by a thin coat of Renaissance wax, buffed off with a clean wheel. The carob piece got the same routine, except it got a coat of Formby's Tung Oil finish before the lacquer. (And I let the Formby's cure a few days before I hit it with the lacquer.)
    Southeast Pa
    2,019
    I like these pretty an functional.. The middle one would be my pick.
    Garry
    13,437
    I like them all, but that black one really stands out to me. Great job!
    Jul 2007
    DSM, IA
    5,719
    I have to agree with you Darren. Great Stuff Vaughn.
    My Website
    12,247
    Vaughn I just never get tired of seeing your great work. You got the word "form" down pat. No doubt there is an artist designer in you. I can never choose only one. Like a kid in a Candy store.
    S E Washington State
    3,777
    Those are really impressive. Simple thing like a paper clip holder turned into works of art.
    Jul 2007
    Des Moines, IA
    854
    Really cool. I have made some of those but they were flatter with the magnet in the center. Where did you get the rings?
  1. quick box
    By Darrell Bottoms in forum Flatwork Project Showcase
    Last Post: 12-22-2010, 09:33 PM
  2. Quick ?
    By Stephen Bellinger in forum Turning Tool Questions and Show & Tell
    Last Post: 02-07-2010, 01:33 AM
  3. quick fix
    Last Post: 06-11-2008, 06:14 PM
  4. Quick & Dirty
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 11-19-2007, 09:13 AM
  5. Replies: 11
    Last Post: 11-26-2006, 04:25 PM
