Results 1 to 5 of 5
Thread: Finial projects and a refinish of a clam shell
    Palm Springs, Ca
    1,167
    Had half the day free so i made a couple finials and started on the finish. I decided not to part them off because I have no current use for them.
    So ill put a few coats of laquer on them and set them to the side until I have a use for them.
    See Picture 1 & 2....................
    Picture 3 is a clam shell (of Monkey Pod - I think) a friend gave me because it was dirty and had some paint splatter on it. I took some laquer thinner and washed it down and rubbed it dry - which took off all the splatter of paint and junk on the finished surface. I let it dry for a few hours and then with 0000 went over it lightly. Then applied Renaissance wax by rubbing it in well, let it dry for several mins and then using a cloth I buffed it off by hand..........Walla.........not bad for a total of 20mins from start to finish.............lol
    Attached Thumbnails Attached Thumbnails Finial-20.jpg   Finial-22.jpg   Clamshell-1.jpg
    Jul 2007
    Des Moines, IA
    854
    nicely done, Dan.
    S E Washington State
    3,777
    Nice work. I like the finials.
    Los Angeles, CA
    2,668
    Nice looking finials and the clam shell looks as good as new. Good work.
    Goodland, Kansas
    4,834
    Great pieces Dan. Well done.
    Bernie W.
  1. shotgun shell display
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 11-16-2014, 12:16 PM
  2. carving a shell.....Updated
    By Rob Keeble in forum Flatwork Project Showcase
    Last Post: 09-02-2014, 06:44 PM
  3. In a nut shell...
    Last Post: 06-15-2012, 04:30 AM
  4. Cannon Shell
    Last Post: 05-18-2011, 10:22 PM
  5. 12 Gauge Shotgun Shell
    Last Post: 02-18-2011, 04:28 PM
